Aftermarket fenders dont fit?
i bought an aftermarket fender for my 89 convertible camaro and the bottom on it does not fit with the ground fx. The bottom of the fender curves on and on the gm fender it goes straight down. anyone else have this problem?
picture of the fender http://www.rickscamaros.com/camaro-f...1982-1990.html
1 Post
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Aftermarket fenders dont fit?
there might be a difference in GFX equipped cars and non GFX... either way you should email customer service, regardless of whether someone responds to your post...
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Don't believe it's GFX. Probably difference in convertible body design for support maybe?
Car: To many to list
Convertible fenders are cut shorter to accomodate the bracing for the vert. You will have to cut it to make it work. Personally I would look for a GM fender before I waste the money on an aftermarket one.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
as i said in another post the used gm fenders are everywhere...half the members on this board have one for sale for the same price as aftermarket ones.
ive got two pm me if you want one and return that crap aftermarket stuff
Car: They all sit.
Engine: LB9,LB9, LS1, LT4, LT4
Transmission: T5, T5, 4L60, T56, T56
u can just cut and weld the bracket from the old fender to the new one that u already have. I had to do that with my 91 Vert years ago. they were modified to fit around the frame brace they added to the convertibles.
Car: 1985 Pontiac Trans Am SE
Engine: 305 Carb
Transmission: Stock Auto Transmission
Axle/Gears: Stock
i would look for a actual part from another 'vert to be safe. if you have the same problem, then do some body work, although it is strange for the fender you got to be different, it does say that it uses factory specs.
Street Lethal
04-30-2019 12:14 PM
kah992
08-19-2015 02:55 PM
aftermaket, aftermarket, aftremarkey, camaro, curves, dont, fender, fenders, fendors, finders, fit, fitting, issue, market, restore
