What Size Air Compressor for Painting/Sandblasting?
Car: 1989 Camaro RS
Engine: 2.8
Transmission: A4
I need to know what size of air compressor! It's all so damn confusing I've searched and searched and no one on any forum I've been on can really answer this question in plain english, I need to know as much as an experienced body specialist would know. What size, what CFM is there a specific brand that you use and what size do YOU use? This is frustrating me to no end!!!!
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: What Size Air Compressor for Painting/Sandblasting?
I have a 15 cfm peerless compressor,with a free air delivery of 320 liters per minute.While you could use something smaller,you dont want to be running out of air while spraying,and using air tools.I guess it comes back to buying the appropriate tool for the job,as sometimes the small compressors just dont cut it.Just my opinion,I hope it helps you.Heres a link that is useful.
Alicat.
http://www.autobody101.com/forums/vi...3363fb1cf33f39
Alicat.
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Great Information, I was just browsing and came across this thread. Good link to auto body 101 too.
1 Post
Car: 91 Z28
Axle/Gears: Stock
My 6.5hp 60gal upright won't keep up with my Harbor Freight blaster. I wait for it to catch up then proceed. It takes longer but isn't as harsh on the equipment.
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I'm just going to be using a 22 gallon harbor freight compressor with the hvlp compressor but being since I'm going to spray the car in sections, ( fenders, hood, bumpers, etc...) I'll be fine. I have a small gravity feed sandblaster even though it's not the best thing in the world It's worked pretty good for me on small stuff.
evilstuie
04-14-2016 08:52 PM
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
air, blaster, blasting, car, cars, compressor, good, needed, painting, recommended, sand, sandblast, sandblasting, size, tools
