need quick answer please
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Can i get a set of rear louvers if they dont have the third brake light cut out? i just found a cheap set of metal hammound louvers and this is whats worrying me, getting these and them not fitting because they dont have that cut out.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: need quick answer please
they should all "fit" the same...just wont have the cut out for the brake light. which here in IN isnt really an issue
for some reason i always forget that they were on the outside of the glass...hmm you could probaly make your own cut out for the brake light
they will def hit it and probably not sit right, had a moment there lol..but if they are cheap and you are half decent at cutting stuff you could make them work im sure
Engine: L31 350
hmm how do those even attach on the outside?
i actually havent seen anything good posted on craigslist in weeks...couple cars im interested in but thats it. if only i had the money ha ha
HoosierinWA
10-07-2015 10:15 AM
