Aftermarket front fenders
Car: 91 Z28
anyone use them? anyone know anyone with them? how well do they fit? satisfied with them? any feedback is welcome... thanks!
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Aftermarket front fenders
I used one on my car. Didn't fit well at first. Had to drill out brace inside rear of fender and reposition and reweld. Metal is thinner, overall quality is not as good as OEM. 300 verses 45 dollars.
There are many companies making these aftermarket fenders, some are better than others.
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
FWIW I put a certi-fit one on my wifes GTA. After I modified it to fit and braced it, it is ok The door radius edge is still off but it was like $66.
On mine 86, I picked up some used ones for $20 and they will prob take as long to fix them as It did to make the sort-a- fit fit.
They are GM and they fit real nice!
hth
hth
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I agree, I'd go GM if possible before AM. I don't replace fenders on many third gens so not sure of better AM ones. If you have to use AM maybe buy it local so you could try a couple of them.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
you can find used gm fenders everywhere in good shape go that route...they are just as cheap as aftermarket new ones and you know they will fit
ive got two of a parts car just sitting in my garage as well as most of the members on this board lol, pm me if you want one
