loose window
Car: 85 Z28
Engine: 327
loose window
My window is really loose. Moves back and forth probaly 10 or more degrees. Is this normal? Also my door locks don't lock when I press the button. While I had door panel apart they worked once, but tried to jiggle stuff around and could get them to work again. Can hear a clicking noise when I press button, but no action. Any help/suggestions would be appreciated
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: loose window
Just a guess but I'd bet the lock actuator is bad. If it clicks then switch should be working. In the tech, how to section there is a section on repairing loose windows. Several things could be wrong to cause the window to be loose, probably a little of all of them. Good luck.
