Change Firebird to Camaro
Car: 1987 Silver IROC-Z
Engine: 305 V-8 300HP LT1 Cam
Transmission: T-5 5-speed
Have an opportunity to get a 3rd gen Firebird cheap, but want a Camaro. What sheet metal would have to change to go from Firebird to Camaro. Not worried about interior, or wiring.
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: Change Firebird to Camaro
Just buy a camaro dude. It's almost sad to think of someone ruining a good bird to switch to a camaro. Plus you may run into legal issues with a camaro on a firebird title.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
IDK about title issues, I mean there are so many bird/maros out there, not sure they care, but I can see where you are with that. The work you will have changing out the rear quarter panels will end up having u butcher a car that doesn't need to be. You can go bird/maro by changing all the front end stuff, headlight harness, body panels, ect. Honestly it's not worth the time and money to do it, but if that's your interest, then go for it.
Also side note, the entire rear fender is different, not just the taillight area, the wheel well flares are diff, the rear fender is an inch or so wider on top on a firebird to begin with, along with the taillight section being different. Do-able, but not normally practical just to turn it into a base model camaro that are still thankfully plentiful.
Car: 92 Camaro Z28
Engine: 5.7 350 TPI
Just buy a Camaro no need to chop up a Firebird, I have seen many Camaro's for sale for low prices.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
just keep it a firebird, they are nicer anyway
I disagree with that quote but if you want a Camaro get one as stated there is a lot of work to be done unless you can do all the work yourself you will get a Camaro much cheaper I was quoted $300 to replace a quarter panel (no parts) multiply that by 2 and find a parts car you will be looking at about a grand easily and you can find a decent Camaro for that price (maybe not rust free) plus it will be a LOT of work.
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
what are people like this even doing in this hobby
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
The number of people on this website currently tearing the surviving population of these cars apart is ubelievable. Visit earlythirdgen.com. There actually are some enthusiasts out there that are attempting to restore third generation Firebirds and Camaros with factory NOS parts, or keep nice original cars that way.
http://www.earlythirdgen.com/
All good comments, I did not purchase the Firebird.
Car: 1991 Firebird Formula
Car: 92 Camaro Z28
Engine: 5.7 350 TPI
I agree i have been debating wether or not to go LS1 like so many others are because of the power potential but decided against it because I wanted to keep the original block. I will rebuild my original block and add some bolt on's for more power though.
Linson
08-21-2015 02:12 PM
92camaroJoe
08-13-2015 06:07 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
