Por-15 on the t-top channels?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '91 Firebird
Can I use Por-15 on the t-top channels? Seems like a better place than any to use it. It won't be visible, so UV light wouldn't be an issue. But is it going to cause problems with the new weatherstrip fitting/adhering?
Car: 2005 silverado ss and 87 iroc-z
Engine: 350 vortec stealth ram comp cams
Axle/Gears: ford 9" 3.50
Re: Por-15 on the t-top channels?
You'll be alright using the por-15. I did the same to mine and it worked out great. Use the right weather stripping though i got 3 sets from classic industrys and after a month and the seems split. summit racing has a good brand im using now
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
