Door Weather Stripping
Hey guys, Im having a bit of a problem replacing the weatherstripping on my door. There are two screws that are imposable to get to with the window in, and I can not get the window out. There must be something I am missing or am not seeing. Please any tips would be great.
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Door Weather Stripping
I'm guessing you're talking about the sash channel pieces that touch the glass on the top of the door since you say the window is in the way.. You have to remove the armrest, then remove the whole inner door panel. After thats off, you'll see two metal blocks with felt on them that hold the window in place, if you loosen those blocks the window will have about an inch of play side to side and you can get the screws out with an open ended wrench.
Hotrodboba400
12-10-2019 07:07 PM
