T tops
T tops
whats up fellas hey i have a 89 trans am w/t tops and it leaks like a old lady with a weak bladder.....lol anyhow are there ways for me to seal my t tops without having to buy that expensive weather strip kit for 3rd gen cars?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: T tops
They are adjustable to a small degree - maybe try that - remove the top screw out of the A pillars and B pillars, move them aside slightly (don't have to remove them), and there are bolts holding the mounting plates (parts with holes) - loosen the bolts and try adjusting some).
Re: T tops
Depends on the leak though. If its leaking due to high pressure washer, could be not adjusted right as in the explaination by camaronewbie. But if it leaks while raining, then the weather strip is dry rotted and needs replacement or a jerry rigged fix. Worst case senareo would be a rust hole in the center faming area.
Re: T tops
ive got the same issue, ive noticed it leakes from the front folds on the t bar, where it has that 90* angle? i put some clear silicone in the crack and let it dry, it worked great til the car sat in the sun for 3 weeks at 110* lol it kinda melted to the t top so when i pulled it off it ended up coming out on the t top, im thinking the silicone under the weather stripping is your cheapest route, im about to do the same tihng to mine
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
