Rear shock tore out of it's mount
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Like it says, my right rear shock peeled away the lower sheet metal of the shock mount. No rust at all. The welds just gave up. Unfortunately, when I pulled over to investigate the noise I noticed a bolt for the sway bar bracket had come loose and was rattling away. So I decided to keep driving home.
The loose shock kept pounding away at the upper sheet metal until I pulled over again and worked out what was going on.
So now I have a nasty cracked, jagged hole where the shock mount used to be. I'm going to try to patch it from above and below. What gauge metal would be best? I was thinking maybe 18 gauge?
Any input would be welcome.
Thanks,
Jon
Thanks,
Jon
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: Rear shock tore out of it's mount
18 is the least i would use look around where the shock used to be mounted and try to match it
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
There was someone on the forum who welded in a Big Strong washer where his shock tower connected
Car: '83 Berlinetta
Engine: 383 CI
I've decided to go with a thick washer up top and another plate from underneath. We'll see how it goes.
Jon
Jon
ambainb
04-25-2016 09:21 PM
LT1Formula
11-16-2015 01:13 PM
1992 Trans Am
08-09-2015 04:32 PM
