Trunk leak
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Trunk leak
The other day I opened my trunk after a rain storm and felt the carpet and it was damp. So I cut out the carpet to keep it from rusting out. A few days later it rained again so I went out in my car to see where the leak was coming from and it turned out it was leaking in both bottom corners of the trunk. The next day I went back there and checked the weather stripping but it looks fine. I really cant afford to have the weather stripping replaced (I dont think its the problem but you never know)and I have tried making the studs go into the trunk more so it would close more. Do you have any ideas on how I could fix this without replacing the stripping? If it makes a difference the trunk is pretty close to the quarter panel on one side and there is a pretty good gap on the other side.
Re: Trunk leak
Soooo...any ideas?
Re: Trunk leak
what do you mean by the seal? That little dark black rectangle on the side?
Former Sponsor
Re: Trunk leak
the weather stripping looks new cuz its not cracked or compressed which is why I thought you were asking if something is wrong with the hatch which is where I think the problem lies
Re: Trunk leak
u need new trunk seal. i have exact same problem. the rectangle piece has flattened out the seal. mine just started leaking form both sides right on that rectangle piece.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Trunk leak
agreeing with M G; I had the exact same problem in the exact same area. those little square plastic pieces flatten out the seal in that spot and cause the leak. new seal will solve your problem. if you want to be 100% of where the leak is coming from, put a light coat of baby powder on the interior plastics and use a garden hose. you should see a trail quickly appear.
Re: Trunk leak
Could I remove the black rectangle pieces and would that stop the problem along with replacing the weather stripping so I wont need to replace it again or would it leak because of the lack of the rectangles?
Car: 1987 Trans Am
Engine: tree-fiddy
Re: Trunk leak
In both 3rd gen's I've owned I've had them leak between the glass and the lid. Pull the plastic from the underside of the deck lid and see if there is any rust or water marks. I just used clear silicone on mine and fixed it without having to take it apart.
