Help identifying parts
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Need help identifying some parts.. They have been off the car and powdercoated for a while now and need some help remembering what hey are exactly.. Please no "I think that is"... Just interested in hearing from people who "know" what they are, I am pretty good at guessing but these are the few parts left over that I need help identifying..
I have more pics if needed..
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Help identifying parts
The one in the bottom right corner goes from the hood latch mount to the back of the headlight mounting panel.
The bracket to the left and right below where you have "Coil Brackets" are the coil brackets.
The one on the top labeled "fender brace" is a fender brace.
I'll see if I can identify any more tonight.. There are a couple others that look really familiar but I just can't place them without looking at the car.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The two left middle braces are for the rear of the AC compressor bracket. One on the left goes from bracket to pass side exhaust manifold bolt, right one to intake manifold bolt
Engine: 350 HSR
Axle/Gears: 3.43
Thanks - so..
1 & 2 = AC compressor bracket braces
3 = Alternator brace
4 = Strut tower to frame rail brace
5 = ??
6 = Hood latch to headlight bar - anyone have a pic of this?
7 = ??
8 = Bracket for brake and fuel lines
9 = Coil brackets
10 = ??
11 = Pass fender to cowl brace
12 = This seems to be a brace that goes from the driver side batt. tray to the front xmember - anyone got a closeup of this?
5 = ??
7 = ??
9 = Coil brackets
10 = ??
Engine: 350 HSR
Axle/Gears: 3.43
Thanks!
Here is a different angle for 10.
Any ideas on 5?
Any ideas on 5?
Engine: 350 HSR
Axle/Gears: 3.43
i'll try and take another angle of 5 later.. I think it is a bracket around the engine somewhere that holds up the wiring loom somehow...
Seem to think that 10 is something similar too...
Engine: 350 HSR
Axle/Gears: 3.43
Sweet, yeah i think you are right. I have a couple others too that I will snap pics of later and post up...
LT1Formula
20
11-14-2015 12:02 AM
Linson
08-21-2015 02:12 PM
