Help with pillar dent removal HELP!
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
ok my camaro was in the garage when a portable camping oven fell and banged right on the edge of the passanger side pillare behind the ttops. its a good sized roundish dent with 2 crinckles, i was advised by my neighbor (drag racer/knows everything about a car that you could want to know) anyhow he said to remove the panels behind the dent and try tapping it out which he would help me with. so how should i try to remove the panels? the dent is right where the panel over the speaker panel is. so how do i remove them? thanks.
Engine: 305TPI
Re: Help with pillar dent removal HELP!
ok so i took a chance at it and got all the interior stuff off down the the metal (pretty easy) but there is the misted blue structure pieces infront of the spots so what should i do? HELP!
If the body is in any decent shape at all, I would have it looked at by a PDR person. The metal on these cars is thin enough that the wrong amount of pressure WILL damage the panel and require body work. If the paint is good and the dent looks workable, let a pro do it. It won't cost as much as fixing it incorrectly and requiring body work and repaint.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
