T-yop rubber mouldings
Car: 1991 Trans Am
Engine: 5.0L
What kind of lubracant can i use on these rubbers so you will not here the t-tops moving [when on] as you are driving the car.Thanks
Car: 1991 Trans Am
Engine: 5.0L
Re: T-top rubber mouldings
what kind of lubracant can i use on these rubbers so you will not here the t-tops moving [when on] as you are driving the car.Thanks[/quote]
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: T-yop rubber mouldings
Sounds like they need adjusted - they shouldn't move at all. Remove the A pillars and B pillars, underneath the 'holes' for the T-top pins can be adjusted.
Car: 1991 Trans Am
Engine: 5.0L
I though they would move a little regardless how tight they were.I just though the rubber should be lubracated with a special greese or oil.I will try the adjustment never the less.Thanks
Car: 1987 Trans Am
Engine: LQ9/L92
i think what you may be hearing while moving is the body flexing a bit. dielectric grease will help a bit, but subframe connectors would help to fix the underlying problem better
Car: 1991 Trans Am
Engine: 5.0L
These cars are unibody construction which means there is no frame. The front is a seperate section than the rear so the sub frame connectors get welded in to connect the rear section to the front. This will stiffen the body and remove flex that was designed into the car originally. Look at pictures of the underside of these cars and you will see what I'm referring to. Also, do a search for subframe connectors and you will see pictures of cars with them installed.
roysatikas
09-22-2015 08:15 PM
