Want Pic of Pass Fender Off With Power Antenna Installed
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Long story short, I removed my power antenna and replaced the mast only to find the relay was faulty .
Now, I'm not sure exactly how the antenna was oriented in the fender as it's been out awhile.
Anyone have any pictures of the passenger fender removed with a factory power antenna still mounted in place?
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: Want Pic of Pass Fender Off With Power Antenna Installed
Look around the clip of wires or computer wires if im right. See the 2 tiny holes around there? Well a metal clip would go there holding the antenna going up there.
I will try and take a pic of it later today.
Engine: Chevy ZZ4
I actually know how it mounts but the problem is I had taken the whole antenna apart to install the new mast. I might have the mast installed 180 degrees spun around which might not matter, kind of hard to explain. I can probably get it back in but if I saw a picture of it mounted from the factory it would let me know if I have it exactly the same or if I switched something around. The only difference I think is which side the antenna cable will mount to the mast, front or back side, depending how I installed the mast.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Engine: Chevy ZZ4
Thanks guys, I got it installed. I finally found my assembly manual which I bought years ago. Only thing I did different on the install was I put the bolts holding the antenna assembly to the main bracket through the other way, going front to rear b/c it was easier, kind of how the picture above shows but my antenna has two bolts holding it on and they are on the side between the body and the antenna.
Car: 85 SC and 87 IROC Both T-Tops
Engine: 305 V8 H Code and TPI F Code
Transmission: 700R AT/OD and 5 Spd.
Axle/Gears: 7.625
Hi, I need help installing a power antenna in my 85 Camaro. Can you send me the installation instructions and drawings, or pictures of it? Richard
Axle/Gears: 7.625
Thank you. Richard
