T-top leaking/t=bar rust
My Trans Am has leaks out the wazoo all over the roof. Every piece of weather stripping is pretty much shot and deteriorated. This is obliterating my headliner at an alarming rate, and also has rusted out the middle part (the t-bar) of the roof. It's mostly on the black panels that's bolted as far as I can tell, but I worry about what's under those.
What's the best way to get rid of the rust so it looks decent when the tops are out? Also where is the best place to get weather stripping at a good price?
And while we're on it, you know the panel/strip that's on the outter part of the roof that sits above each side window and just lips over the glass part of the roof itself.... boths sides are starting to fade to a whitish grey color due to sun and weather. What's the best way to repair that and have them black like their supposed to be again?
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: T-top leaking/t=bar rust
I have a T-bar if interested. It does have rust on the ends that needs to be blasted but is otherwise in good shape.
Car: 1984 Transam
Engine: L69
Transmission: Auto 4spd 700R4
Axle/Gears: Richmond 3.73.1
As far as the t-top trim pieces you mentioned, I used trim black by duplicolor,
its not too bright and has a decent finish. you can clear coat if you desire, I didn't.
Former Sponsor
We carry the Pontiac T-Top Weatherstrip kit for your car. If you have any questions about it,I'd be glad to help.
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-22-2015 08:28 PM
IROCZDAVE (88-L98)
09-06-2015 06:23 AM
