How to open hatch, 82 Z28, Hatch motor broken.
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
As the title reads, i need to figure out how to open the hatch on an 82 z28, and the motor is shot, so it needs to get open for fixing.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: How to open hatch, 82 Z28, Hatch motor broken.
Use the key. Just kidding. Check the fuse. May be burnt out. It's usually the ACCESORY fuse depending on the previous owner (can be the LID fuse aswell. Also if your hatch panels are removed or can be removed, there is a little slot where an aftermarket key cylinder shaft gets inserted to turn the lock to open. But if you dont have access to assembly, Then visit a locksmith. They will charge you but you'll get it open.
Engine: 357
Hmm okay, ill give the fuses a try. I could fit in the back of the hatch and try and remove some panels to get at it.
Engine: 357
Basically, i have no idea whats up with it, got the car month or two ago, back has ice in it, so tried popping it with the button, no go at all, tried the key, no go at all, not even a single noise.
With the hatch glass down, you wont be able to remove the panel because there are I think 2 or 4 screws right at the striker plates, which are covered by the closed hatch glass.
Engine: 357
Thats pretty bummer, ill go out and look at the fuses, bb in a few
Does the car have a hatch release button on the console? Is it an auto or a manual trans? If it's manual it needs to have the ebrake engaged to pop the trunk, and autos need to be in park.
Engine: 357
Wooo, it was the fuse, it wasnt ASSESSORY or whatever, it was worn out and said like CLU something. But it pops, is there a up/down motor on 82's? so you dont have to slam it, it glides shut.
Thanks for the help btw.
Did you try opening it with the round head key for the doors. Hatch lock is located behind the folding down license plate holder.
Then no, you have to slam it shut.
1992rs/ss
16
01-28-2016 10:58 PM
