Removing cross member to replace main and rod bearings
Car: 1986 IROC-Z28
Engine: 5.7L L98
Transmission: 700R4 OD
Axle/Gears: B&W 3.27 Posi- :D
I was just looking up how i can replace the main and rod bearings in my 86 iroc-z. i know since i have the cross member i have to lift the engine to clear it. but cant i remove the cross meber so i can make things a littl easier. then i can just drop the oil pan. i can do bearings while the motors still in, i just wonder if i can take out the k-member to make less likely to break the pickup or anything else. thanks!!!
1 Post
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Removing cross member to replace main and rod bearings
You'd have to compress or remove both springs, unbolt the struts, unhook the front brake line crossover, unbolt steering idler, separate steering cross link from pitman arm, safely support the weight of the motor, unbolt motor mounts, unbolt cross member triangle braces, then the six mounting bolts. If you pull the motor, you can clean it up and throw some new gaskets at it.
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I agree that you're making more work for yourself that way and you'd have to work in a much tighter/more dangerous space underneath an engine held by a hoist.
