Leaving my iroc for awhile
Old 02-03-2010 | 09:06 PM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
Hi all well i had a few questions for you. Im in the Army and just got my orders to spend some time in Italy and most likely it'll be for at least a year or two. K so i just recently dropped 3 grand to have a guy do all my body work and paint the car and i pick it up when i come home for leave at the tail end of march then i leave in two weeks. So my big question is what should i do to prep the car for longterm storage its gonna be in a garage and under a cover. What else should i do? any advice would be much appreciated
thanks jeremy
Old 02-03-2010 | 09:36 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Re: Leaving my iroc for awhile
Make sure the coolant is in good shape, do a fresh oil change (synthetic preferably), add Sta-Bil to your gas and try to make sure you run some through the system (by driving or idling a while). Disconnect the battery and, if possible, put it on jack stands.
Give it a nice cleaning too so that it will be ready to go when you get without having to work on it.
Thanks for you service.
Old 02-03-2010 | 10:04 PM
madhatter's Avatar
Look into a car pod. its kinda like a big zip lock bag you drive your car into and seel. then you can buy big bags of silica to throw in with it to suck up the humidity. the car pods are like 200 and the silica bags are cheap. the pods are made out of tough material and they wont scratch the car. that is about the best way to go.
Old 02-03-2010 | 10:14 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
why the jack stands?
to keep the tires round?
Old 02-03-2010 | 10:23 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I'm with Duts87ss
Or bring it over to me--it would be driven ONLY on sunny days, washed weekly, washed & waxed every 2 weeks, garaged when not driven,..
Yes Sir-- Thank You for your service
(edit)
madhatter has a Great idea!!
Old 02-03-2010 | 10:26 PM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
well if your in kansas im sure that can be arrange
Old 02-03-2010 | 10:47 PM
Duts87ss's Avatar
Yeah. Not sure if there's really anything to it, but it keeps the tires and suspension unloaded. May just be mumbo jumbo.
Wade787b
09-29-2015 02:15 PM
dyeager535
08-28-2015 09:10 AM
Thornburg
08-25-2015 02:46 AM
Fronzizzle
08-17-2015 03:52 PM
mustangman65_79
08-11-2015 04:17 PM
