Troubleshooting a possible problem
Car: 1984 iroc
Engine: 305 tpi with ac
Transmission: Automatic
I am restoring and hot rodding my 88 iroc.. I plan to put scissor doors on it, but it has t-tops. Will the weight of the door effect the scissor door hinges? Will they even work at all with the hinge? I would really like some help as I dont really know what I should do.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Troubleshooting a possible problem
Not sure about the doors or why you'd want that on a third gen but im curious, what's an 84 iroc? An 84 maro with iroc parts swapped onto it?
Car: 86 IROC-Z28
Engine: LB9
If you do everything by the book, the T-Tops should have no effect as the scissor door hinge still mounts in the similar location as original hinges and no weight will be supported by the window. However, I agree with last post, WHY? Do you mean to say you have a 84 Z28HO, that is the closest to an IROC in 84 that I can think of?
Car: 1984 iroc
Car: 1989 Camaro IROC-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
on a thirdgen id rather just have suicide doors if i had to have something other than stock
