Camaro/Firebird t-tops interchangeable?
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I tried the search and couldn't really find anything about it. I am wondering if the t-top is interchangeable between the Camaro and Firebird within years. Not the glass/lexan, tha actual roof/t-bar. Basically, I have a rusty t-top that is pretty bad and was wondering if I could get away with using the t-top roof off a donor Camaro on my Firebir or if they were different in some way. it's an '88, so what years would be ok/the same? I understand that some of the years varied the t-top glass, so maybe the roof is different? Just trying to figure out my option before I spend a lot of time repairing the rust.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Camaro/Firebird t-tops interchangeable?
there are 2 different style t-tops, factory and the C&C ones.
as for the roof, im pretty sure the sheet metal for the birds and camaros room is the same.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
should be - the tops themselves are interchangable - I replaced my lexan tops with glasstops from a bird.
you wouldnt happen to still have those lexan tops?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Look up madhatter. He had a long thread on here a while back(maybe a year or two ago) about his roof swap. He bought a hardtop car and wanted t-tops so he swapped the entire roof. He should be able to answer your questions.
Car: 1992 Camaro RS
Found it finally. Seems I have way to many saved threads. Anyhow, here is the link:
https://www.thirdgen.org/forums/body...-top-roof.html
Car: 1992 RS
Engine: Carbed 350
I might - I'd have to go hunting in my many junk piles to see. Not sure you'd want them though, they were crackled the way all the lexan tops get. I still have to get my locks out of them and put into the glass tops so I can lock them too. But if interested, I'll look and see.
PM me so I don't forget - it's too dark and cold tonight lol
Car: '87 Trans-Am
Awesome, thanks.
Car: '87 Trans-Am
Does anyone know if you can buy replacement t-top seal channel metal? You know the little lip that the t-top seals slide/slip into up there, can that metal channeling be gotten anywhere but another donor car or am I going to have to make that out of some sort of preformed metal and welding if I don't replace the whole top of the car?
Car: 1992 RS
Engine: Carbed 350
You mean this piece?
http://cgi.ebay.com/ebaymotors/T-TOP...Q5fAccessories
Of course they are available for way less!
Car: '87 Trans-Am
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
