92 GTA resto
Car: 91 Formula
92 GTA resto
ok, finally getting around to start working on the car. first off, everything is getting pulled off the car(nose, fenders, engine, trans, fuel tank, int).. i have dr side fender to replace, but still need a pass one. i need to know a budget minded way to clean/update under the hood(leaving harness in there), and how to fix the driver side floorboard, it has a high spot, from an earlier accident in life according to carfax... i intend on doing all this myself at a small private repair shop where i work, but am a novice at body work. do not have the money/nor want to pay someone to do the car.. i saved her from salvage this year... as i pull it apart, i can take pics if that helps.. I want to make it a shell, repair body parts, install subframes, get underbody/underhood painted, then suspension, then paint, drivetrain, and finally interior.. i plan on making this a long term project. i work 2 jobs and all that crap... so any info or ideas will be appreciated. thanks
2012sergen11
10-13-2015 07:38 PM
