window sweep / weatherstrip removal help
Car: Restoring 85 IROC-Z, 89 5.0 notch
Engine: to be 383
Transmission: T-5 and T-5
Axle/Gears: 3.27in IROC and 3.55 in mustang
I have been trying to take my passenger window lower outer sweep/ weatherstrip off and I can't get the two middle screws out because the window won't go down far enough. I have loosened the window adjusters to help it tilt in some but even then I can't get the screwdriver on it enough to break the torque to get them loose. I can just barley get an angle on them but its not enough. Any tricks short of taking the window out. I took it out on the driver side and it kind of sucks and was hoping there was a trick to getting to those two middle screws on the sweep. Thoughts? Any help would be appreciated.
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: window sweep / weatherstrip removal help
I used a phillips bit clamped in needle nose vise grips worked pretty good for me.
Engine: to be 383
My bits are too long to fit. I guess I could grind one down and see if that can get in there. Thanks for the tip. If anyone else has any others let me know.
1992 Trans Am
05-10-2023 07:19 PM
1Aauto
Sponsored Vendors
08-26-2015 02:18 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
