Hit a Tree... Need advice
Former Sponsor
Re: Hit a Tree... Need advice
Ouch, that's pretty bad. You're going to need to find out what all got damaged. The bumper cover, inner bumper, hood, and lower spoiler are all bolt on pieces that can be easily replaced. However, your core support is damaged and it's possible that other structural pieces may be damaged as well. I think you need to find out exactly what pieces are damaged and find out how much it will cost to replace them. Depending on the overall condition of the car it may not be worth fixing but that's up to you.
I know we have most of the pieces you need available on our site if you want to check prices
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Car: 89 RS
Engine: 2.8
You could easily find a parts car for that. You just need to make sure the subframe is not bent. That can be fixed too but its up to you how much you want to spend. The other option would be to find a rust free body and transfer your motor and trans.
Kevin
Kevin
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
No need to find out if the frame is bent. It definatly is! the reinforcment being pushed in like that has caused the frame ends to be drawn inward. That car needs some serious time on a frame machine. I can assure you the repair costs will out way the value of the car
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
I've fixed worse, but it's going to take either a frame machine or a chassis jig to get the car straight again....I'd say find another car and use this one for parts is probably going to be the best option....unless you have access to a frame machine with a good tech running it!!!!!!
Car: 2002 trans am
Engine: ls1
Transmission: t56
Car: 1985 trans am
Transmission: 5spd
yeah, if the frame is bent then definitely get another car and use the parts on your car that you want.
Start pulling parts off to see what needs replaced. The core support can be replaced fairly easy. The bumper supports will need some work, but you would be suprised what you can do with a few tie-downs, a come-along and a 10 tone port-a-power.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
This ones pretty simple. Time to go car shopping !!!!!
1 Post
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
here is everything you need for real cheap,
http://usautobodyparts.com/catalog/CHEVROLET/CAMARO%20(1982-1992)/1990
This website does not have bumpers!!
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Yeah, find another one, and stop hitting trees...lol!
PS- Where in PA are you? You look local to my stomping grounds.
Car: 1985 trans am
Transmission: 5spd
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
www.yearone.com
or go to your local Chevy dealer and have them contact any dealership in Michigan... I know that sounds random but when I replaced my bumper cover, some random dealership in MI had fourteen of them sitting around in a warehouse...
off topic... but are you Grant from the Camaro Lovers group on Myspace??
1 Post
Engine: 350 Tpi
Axle/Gears: 3.08
www.yearone.com
Those bumpers look pretty expensivee, ill have to shop around some more and check out all the other prices too.
The first link with the fenders were pretty cheap, only 60 bucks!
1 Post
Car: 88 t/a 92 rs camaro 88 firebird
Engine: 305 tbi in both
Transmission: auto camaro 5spd firebird th375
Axle/Gears: 3.73 minispool
dont hit trees let off the brakes and steer
deer are fast trees are hard and cops are sneaky
could use a rear bumper myself 92 rs (rust) only rust on the car let me know south central pennsylvania
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
Haha, small world... I learned the hard way a while back on an old project; if you don't have the cash for OEM replacements - start junkyard hopin'... The fit of aftermarket fenders\hoods\bumper covers\etc is horrible... (You get what you pay for) You would end up spending more money trying to straighten, shape, and knock out all the dings and dents from being mis-handled\stored... Even after that its still not exactly right... It'll be worth it in the long run to go the used or OEM route...
1 Post
Engine: 350 Tpi
Axle/Gears: 3.08
http://usautobodyparts.com/catalog/C...982-1992)/1989
Think it'll fit right?
Car: 1985 trans am
Transmission: 5spd
as far as i have heard any aftermarket body panels will take some body work to get them to line up correctly.
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
www.yearone.com
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
$319 with free shipping... If your planin on just hack'n it apart, go the junkyard route... Save ya a couple bucks and you wont sweat over it as much if you mess it up... What are you planning on doing anyway??
Car: 1990 Camaro rs
well took her into the bodyshop today... i lined up a donor car i'll be getting for free. so i'll have her on the road in no time... thank god for connections
Car: 1985 trans am
Transmission: 5spd
haha, yeah, plus if theres anything left in the other car, you can part her out and maybe end up making money over this tree. haha
Car: 87 GTA
So what do you think about these fenders?
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
My advice search craigslist to find a cheap beat up parts car, then swap everything over to make one good car. There are alway people on craigslist selling a thirdgen camaro for under $500 cuz they are beat up and need work, theres a good parts car.
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
read the thread, he has a parts car and it was last said to be at the frame puller
HoosierinWA
10-07-2015 10:15 AM
