No pop-up Hood??
No pop-up Hood??
I am trying to find a hood for my gta with the headlight doors molded in..
Is there any? I found one listed on Showcars bodyparts but I have heard bad thing about their service and quality.
Does a camaro hood latch at the same place?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Re: No pop-up Hood??
Camaro hood is a different shape really. If you had a spare hood you might get away with just trying to fab it yourself. Shouldn't be much of a process and will work probably better on a fiberglass one. Going with foglamps or hella lights?
Car: 87 GTA
From the firewall to the strut towers, the hoods are about the same. From there forward, the Firebird front ends drops about 4" lower, so the Camaro hood would bolt on, "close", but be nowhere near latching, nor even stay down while driving. Be like having a parachute!
Several other places make hoods without the cutouts, mainly because of the drag race crowd. And your looking at stock or cowl induction. Never seen another option.
You could always see about getting your stock headlight doors molded in to the hood you want to usee.
Car: 1995 RX-7 LS1
Engine: 2000 LS1
Transmission: t56
Axle/Gears: 410 limited slip
Are you completely removing your pop up lights then? I guess I am a little confused on what you are going for here. I have owned many cars with pop up lights 88 formula, 92 celica, 92 Stealth, 95 rx-7, 91 formula... And Im having a hard time picturing how the lights would work if the head light covers were molded in.
are you just gonna use your foglight location as headlights and remove your pop-ups?
Car: 87 GTA
![](http://carphotos.cardomain.com/ride_images/1/2862/661/7152830030_large.jpg)
Car: 87 GTA
Put different lights in. You don't HAVE to go with what Redraif did. Get what you want.
But it gives some good info on how one person did it.
You may want to check on you state laws reguarding headlight placement. In Kansas, the headlights on any car manufactured after 1959 must have the headlights at least 24" from the ground but no more than 54". Just a thought before you go to too much trouble only to find out that it is illegal.
Car: 87 GTA
It is now 2" lower, but nobody ever checks & I'm perfectly fine with my car being "illegal."
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
