ground effects
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
ground effects
where can i find ground effects for my 1991 camaro rs my nose part has 2 big cracks in it and probability is not fixable ive looked on alot of sites and can't find much
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: ground effects
Junkyards, junkyards and junkyards. My favorite place to go, and the first place i would look to find cheap parts. Now if you don't like that idea try YEARONE or Ecklers. Now are you talking about the actual bumper cover or the chin spoiler?
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: ground effects
2 cracks? fix it! got pics? The good thing about fiberglass is if you mess it up you can practice/perfect it another time....
Car: 1992 RS
Engine: Carbed 350
Re: ground effects
None of the effects, nor nose cover, nor tail cover, are fiberglass - and you can't use fiberglass to fix them. They are a plastic material, and you must use the proper repair materials for repairs to work.
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: ground effects
both the people above are right. you do need the proper repair kit!! but if it is fairly small you can probably fix it and don't necessarily have to get it perfect the first time. the bumper repair kits i have seen are two part epoxies that you mix and use like bondo. if you sand too much, add more. post some pics because depending on where you live a 91-92 chin spoiler could be expensive/ impossible to find!
Car: 88 iroc camaro
Axle/Gears: stock
Re: ground effects
it looks like you need a new chin spoiler, i was picturing a small crack on the very bottom like what mine looked like when i bought my car. It looks like you may also need some new fenders and turn signals too. who painted your car?
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Re: ground effects
i think its the factory paint not sure and turn signals are good i found fenders on a website for around 130 a peice but i can find a 91 chin spoiler anywhere well maybe when i get the money i can find one on here hopefully
Car: 88 iroc camaro
Axle/Gears: stock
Re: ground effects
I could be wrong but it looks like your turn signals have been painted over or at least have heavy over-spray on them. either that or they just really need to be wet sanded and buffed.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: ground effects
you could sometimes find some in here cheap and in perfect condition around $200 for all of the gfx just search
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: ground effects
check into 3M's duramix products....I will be using them to fix some spots on my chin spoiler and nose. They're a bit pricey, but you get the right product to repair you're spoiler and have some left over for future repairs. You'll need the Duramix 4240, 4991(dispenser), adhesion promoter, degreaser and EZ sand plastic parts repair. Got all of it at amazon.com
Damon
09-26-2015 04:29 PM
