Driver door sag
Driver door sag
I'm new to the forum and had a question. It looks very likely I'll be buying an '85 Trans Am with the LB9 motor. The car has a sagging driver's door. Is there a best way to fix the sagging hinge problem? The passenger side door is fine.
1 Post
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Driver door sag
Yep,best place to find the bushings needed is TDS..That is if the hinge itself isn't falling apart.Heres a link to Lons site.He's a member here also. www.topdownsolutions.com
Re: Driver door sag
Thanks, really appreciate your help with the door question - . I did end up buying the car - I'll try to post some pictures of it in the next couple of weeks.
