The ULTIMATE budget paint job (pic heavy)
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Some of you probably remember my original budget paint job thread that centered around using Rust-O-leum. While that produced a decent paint job at a very affordable price, the upkeep on said paint job was quite a bit of work. It required nearly weekly waxing to keep it from dulling. So, I decided to strip all of the Rustoleum off and start over again with a better paint that I know for a fact can withstand the extreme sun in Central Texas.
The paint that I used this time is Valspar Tractor & Implement paint. I've used it many times in the past on various horse & cattle trailers and it holds up great. The best part is that it's only $29.99/gallon. Of course there are added expenses such as thinner and hardener. It suggests using naptha as a thinner for spraying, and it works great.
Here is what I used:
![Name: P9200043.jpg
Size: 125.2 KB](https://www.thirdgen.org/forums/attachments/body/424620d1501491262-ultimate-budget-paint-job-p9200043.jpg)
Paint material costs:
1 gallon Valspar Massey Ferguson Red - $29.99
1 gallon Naptha ---------------------- $13.99
2 8oz cans of hardener--------------- $12.99 (X2)
Total cost for just paint supplies-------$69.96
This does NOT include all the sand paper, masking tape, etc.. that goes into a paint job.
I disregarded the mixing instructions on the paint. I poured 16oz of paint out of the can and mixed in both cans of hardener (The paint calls for only 1). Then I used a 2:1 mixture of paint to naptha.
After all the prep work was done I sprayed the paint with the $12 purple HVLP gun from Harbor Freight. My compressor is a 25 gallon Craftsman.
Once again I sprayed the paint in my gravel driveway under the oak trees. I stretched a tarp out over the hood of the car to minimize any sap that might fall on the fresh paint. I applied 8 light coats with about 10-15 minutes between coats. The air temperature was around 100* +/-.
Here is right after the last coat:
![Name: P9200032.jpg
Size: 119.9 KB](https://www.thirdgen.org/forums/attachments/body/424621d1501491262-ultimate-budget-paint-job-p9200032.jpg)
![Name: P9200033.jpg
Size: 149.9 KB](https://www.thirdgen.org/forums/attachments/body/424622d1501491262-ultimate-budget-paint-job-p9200033.jpg)
Tidan (04-27-2020)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: The ULTIMATE budget paint job (pic heavy)
Doesn't look too bad at all from the pics. How does it look up close...in direct sunlight? I think Ill be using the "paint it outside method" too as last time I rented a booth the jackass hadn't maintained his downdraft booth filters and I got filter garbage all over the paint. Would have been better off outside :-(
Engine: LT-1
The paint was dry to the touch about 4 hours after the last coat was sprayed.
I waited a couple of days and then the wet sanding began. Since there was very, very little orange peel I started with 1000 grit and then went over it again with 1500 grit.
Polishing:
I used the $30 high speed buffer from Harbor Freight with a wool pad and Meguires Ultimate compound. Then I switched over to a foam pad and went over the whole car until it was buffed out to a mirror shine.
![](http://i497.photobucket.com/albums/rr340/E_Plummer/91%20Firebird/PA070053.jpg)
Driver door:
![Name: PA070063.jpg
Size: 65.6 KB](https://www.thirdgen.org/forums/attachments/body/424618d1501491262-ultimate-budget-paint-job-pa070063.jpg)
Passenger door:
Polishing:
Driver door:
Passenger door:
![Name: PA070064.jpg
Size: 77.6 KB](https://www.thirdgen.org/forums/attachments/body/424619d1501491262-ultimate-budget-paint-job-pa070064.jpg)
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Looks sick, what type of sprayer do you use? What is your air compressors specs?
Engine: LT-1
Here is the "finished" product. These pics were taken today. The direct sunlight makes it look lighter then it actually is.
![Name: PA190005.jpg
Size: 160.1 KB](https://www.thirdgen.org/forums/attachments/body/424610d1501491244-ultimate-budget-paint-job-pa190005.jpg)
![Name: PA190012.jpg
Size: 101.1 KB](https://www.thirdgen.org/forums/attachments/body/424611d1501491244-ultimate-budget-paint-job-pa190012.jpg)
![Name: PA190009.jpg
Size: 152.5 KB](https://www.thirdgen.org/forums/attachments/body/424612d1501491244-ultimate-budget-paint-job-pa190009.jpg)
Engine: LT-1
I have few gnats here and there that will be forever immortalized in mine, but you'd never see them if I didn't point them out to you from 3-4" from the surface. Actually, it's just their legs (which are tiny). I went around and around the car after every coat with a pair of tweezers picking them out but a few legs got stuck in the paint. Just make sure you wet the ground real good to keep the dust down.
Car: 87 Camaro IROC, 85 IROC Roadste
Engine: 5.7 V8 350 TPI, 383 - Coming Soon
Transmission: 700R4, Turbo 350
Nice! Paint job turned out great! Good job on the work. Wanna paint mine next? Lol
Car: '87 Trans-Am
One thing I just noticed though is that paint is enamel. I'm sure you know this, but others may be interested to know that enamels dry very hard...like a rock hard shell once cured. Which is fine, but if you do get any kind of orange peel or need to sand down high spots/runs at all, it will be much more difficult than on a urethane one. So just make sure you take your time and minimize runs/orange peeling if using an enamel is all I'm getting at here. It came out very well though...just happened to notice the enamel label and thought it might be a good idea to mention.
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
WOW. less than 70 bucks for a paint job like that. Very nice!
Engine: LT-1
That's exactly why I used it. I used this same paint last November when I changed my car to white. I came out after work and there was a line all the way down the side that looked a little discolored. It definitely looked as though someone had keyed it. I took it home and hit it with the buffer, scratch gone!
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
I comend your efforts. Painting it out side must have been a pain, how did you ever keep the dust down? I know of people who have painted their cars with Rustolem and tractor paint and none of them have came out as nice as yours. It has a mirror smooth finish, it is just awesome that you did it for $70.
1 Post
Car: 91 RS T-top
Engine: 305 tbi
Axle/Gears: 3:42 fourth gen disk brake
Nice job. My rustoleum paint is flaking off. I took it to the car wash and it peeled back some of the paint so im just going to sand it down a keep it primer till i can get some good paint. It looks alot better than the rustoleum.
1 Post
Car: 1985 Pontiac Trans Am
Thats the best looking cheap paint job i have ever seen.Hats Off!! Laying down the paint right and wetsand and polish skills really look great.
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
Awesome paintjob
my only question is what prep work did you do for the paint did you sand the car then primer it or did you just sand it and then paint?
![good job!](https://www.thirdgen.org/forums/images/smilies/goodjob.gif)
Engine: LT-1
I used the Valspar tractor primer in the rattle can and wet sanded with 400 grit. After I wiped it down with a rag and acetone I was ready to lay the paint. You can spray it over factory paint, I just had way too many coats of paint on the car.
Tidan (04-27-2020)
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
dude you keep on doing the coolest stuff!!! i wish u were my neighbor or something lol
Car: 1989 GTA
Engine: 5.7 350
real nice man, I just hope when i do my paint job that it comes out half as nice as yours.
Car: 87 GTA
Shame on you!
Car was down for all that time & you didn't lower it, while it wasn't being driven?!?!
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Paint looks great though!
![get banned](https://www.thirdgen.org/forums/images/smilies/banned.gif)
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
Tidan (04-27-2020)
Engine: LT-1
Here's a pic I snapped this evening that really shows off the shine.
![Name: PA230025-Copy.jpg
Size: 121.3 KB](https://www.thirdgen.org/forums/attachments/body/424318d1501490629-ultimate-budget-paint-job-pa230025-copy.jpg)
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
paint looks great, if i can find an air compressor might be a good project for next summer as my paint is fading again
1 Post
Car: 87 Camaro
Thats awesome, I was a big fan of your rustoleum paint job but this is even better. How do you get the windows covered up so well, and how do you go about painting the T top bar?
Car: 1988 Camaro IROC-Z (Daily driver)
Engine: 350 5.7 Tuned-Port Injection
Transmission: 700R4+shift kit
Axle/Gears: 3:73 Posi. (Soon to be Eaton 4:11's
Very nice. Im lookin to paint my IROC. Only thing i thought about this is that you sprayed the car on the ground, so when you walk or anything like that, dust gets kicked up onto the paint, watd you do to avoid this?
The 88 IROC
The 88 IROC
![Name: IROC3.jpg
Size: 7.1 KB](https://www.thirdgen.org/forums/attachments/body/424299d1501490590-ultimate-budget-paint-job-iroc3.jpg)
Engine: LT-1
I sprayed it in my gravel/sand driveway. I SOAKED the ground all around the car with the water hose. I wet it down in about 20-30 feet diameter around the whole car. It's not dust you have to worry about, it's the mosquitoes and the gnats. But, all of it will wet sand out pretty easily. Just make sure you have a pair of tweezers handy to pick off a bug if it lands in your wet paint.
Car: 91 RS, 89 IROC
Engine: 305 TBI, still deciding
Transmission: 700R-4, still deciding
Axle/Gears: stock, 3:73 IROC
Dang, that paint job is sweet. Think I will have to do this to mine.....Might have to ask you some questions when I get closer to doing it if that is ok.
Dave
Dave
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
It looks great ! I wonder how it will hold up in time though.
Car: Camaros and Suburbans
Engine: V8's
It's tractor paint; IMO if he keeps it waxed, [i.e. protected], it should last "until the cows come home," - pardon the pun. I don't recall seeing many farmers giving the weekly / bi weekly wax job to their combines if you know what I mean. That paint on a properly prepped metal surface is intended to last and shine - with the occasional high pressure power wash - for years to come... no doubt!
Engine: LT-1
It' holds up great. I've used this stuff for years on my horse/cattle trailers that sit out in the weather all year and they still look great after several years....and those don't get waxed.
Engine: LT-1
The paint has rolling instructions on the can. The only difference from spraying is it says to use mineral spirits when rolling and naptha when spraying.
Enamel can look good, so can urethanes as well. We painted cars for decades with those two products.
However, that said, we have moved onto base/clear for a reason.
Below is a pic of my car after using a urethane single stage, with a clear coat on top.
![](http://home.comcast.net/~thirdgen89gta/cars/thirdgen89gta/painted/painted_04t.JPG)
![](http://home.comcast.net/~thirdgen89gta/cars/thirdgen89gta/painted/painted_06t.JPG)
What did I do? Machine sanded the car with 180grit, followed by wetsanding with 400.
Really helped out the paint where it was.
This is what it looked like before.
![](http://home.comcast.net/~wjrneo2/cars/gta_home/gtab4-02b.jpg)
Car: 1991 formula
Engine: 350 tbi
Axle/Gears: 308 posi
car looks awesome so what made you go from red to white then back to red?
#42
Sounds pretty good then, I'm gonna have to try that. I guess metallics don't exist on that kind of paint ?
#43
Car: Faster
Engine: Than
Transmission: You!
Looks good, but doesn't the front and rear bumpers need a flex agent added to the paint because those parts are flexable urethane?
I would be worried about it spider-cracking over time....
#44
Engine: LT-1
I've had this type of paint on my car for over a year with no issues or problems. When it was white I took the front bumper off when I did my motor swap and put it back on and it never developed any cracks.
#45
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
beautiful paint man would have never thought it was done at home
#47
i have a question though will the shine last like a normal single stage automotive paint or will it have to be polished and waxed often to keep its high shine?
#48
As one who has spent big bucks on paint, equipment, and supplies, I have been reading this and other similar threads with interest.
What is especially appealing to me is the idea that you can put a quick paint job on a car that is a daily driver, and thus likely to get some bumps and bruises in normal use. I'm going to try this method on my 86 bird that has 230K miles on it, because I need to do some serious body repair, and it will be easier to justify cost-wise.
One reason is because I have two other birds, and this one, although it was the first, is easily the least valuable of the three.
#50
Could you top off the tractor enamel with a conventional clear? That could cut down maintainence work if it would apply correctly.
I think I remember seeing a post from a year ago or so, a guy did his black 91-92 'bird with dirt cheap base topped with really good clear.
