2010 camaro head lights on a third gen
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
I wonder what it would take to install 2010 camaro headlights in a third gen.I have never seen the halo lights in person to estimate mods needed.Anyone ever seen this done?
this could end up being really cool if done right
Car: 87 GTA
Re: 2010 camaro head lights on a third gen
I don't think round lights of any kind would look good on the straight lines of a 3rd gen Camaro.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You'd would have to measure the height of the 2010 lights. They look too big to fit.
There have been threads about guys who put rounds lights on their car but it would TAKE A LOT of work to make them look good.
I dont know about the 2010 Camaro lights, but this thread might interest you with the angel eye version.
https://www.thirdgen.org/forums/auto...onversion.html
Car: 1991
Transmission: 700
I saw a really ugly Third Gen here in Dubai where someone put a 2010 front end and rear end on it. It looked like total ****.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Dunno, the 2010 Camaro headlights sit in a square frame. I agree it would have to be done right for it to look good though.
Car: 99 HOSS 6 Speed
1 Post
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
please dont give him bad ideas, yea that mod looks great at the cost of much needed structural integrity in our already extremly loose bodied cars
Car: 88 IROC-Z
Engine: 383
Im going with the BMW E-36 angle eye cause I can reweld a small brace to reinforce the removed structure and I love the look!
Car: 1992 RS CAMARO 25TH ANNIVERSARY
Engine: 305 TBI
well i seen one here in missouri and the lights look sweet .also they are not completly round more oval i think and a little square i dunno maybe im seeing it wrong but thats the shape i get.
1 Post
aren't you aware of how loose the F-Body is? they flex, ALOT, and that upper core support is key a key support in preventing flex in the front end, cut away 3/4 of that and what are you left with? frame rails that can flex and possible break away
Car: 88 IROC-Z
Engine: 383
Any suggested bracing that would get the job done?(eg.triangulating rad support to body/frame?)
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Car: 84 Z28, 05 Mazda 6
I love that mod might have to do it soon... As far as cutting the rad support, if your really that worried about the frame flexing flip the piece you cut out upside down and weld it back in use it as a lower mount for the housing and boxing in the sides would also reinforce the structure. That way you can have your angel eyes and not sacrifice rigidity.
And as for the 5th Gen Kit on the 3rd Gen I'd do it but only if I could put an LS9 under there and a 6 speed.
I'll be here all week!!!
Car: 88 IROC-Z
Engine: 383
1 Post
Honestly I would make a bolt on plate that would wrap around the back of the cut areas, I would definately invest in a wonder bar and strut tower brace. And look if you have the three triangular braces for the frame rails. And lastly sfc's will help stiffen the entire car
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
i REALLY want to see this done. i think it would look good if someone could mod it so the blinkers could be moved next to it in the headlight well to fill in the gap.
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Car: 89 camaro
Engine: 350 LT1
Transmission: 700R4 slushbox
Because not everyone is a Stock ****. People who mod their cars are just adding their on flair/style to it. It's an expressive art form.
![yup](https://www.thirdgen.org/forums/images/smilies/yup.gif)
I like doing things that sets my car apart from everyone else. I'm adding projector HIDs too mine in a couple weeks. Already modified everything else to LEDs. I like giving my car more modern features.
I'm not really a fan of what was mentioned here, but if the OP thinks he can do it and make it look good. All the power too him, hope he posts pics if he's able to do it.
Car: 92 rs 25th ann.
Engine: 383
Axle/Gears: 342
I think that what ever suits your style is good enouph for you if othres dont like it so what its not there car. If you add strut tower brace and a wonder bar, abd maybe weld in some triangular suports you should be just fine.
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
I'm not sure about the 2010 camaro lights but I've seen a few 3rd gens with the bmw lights put in them. There is even a thread on tgo that details step by step with pictures on how to do this conversion. Its fairly expensive but worth while if you want the halo's
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
I am thinking about it. I think after it is tucked in there it would look good.
1 Post
Engine: 2002 SS LS1
Imagine them tucked in behind everything. The BMW halos a Guy on here did looked sily before he shoehorned them in there.
I'm using projector headlights from a 99 Suburban and also using ccfl halos from a BMW Z3 taped off at the bottom to give it that "parenthesis halo" look from the 2010 Camaro.
![Name: DSC02298.jpg
Size: 55.8 KB](https://www.thirdgen.org/forums/attachments/body/375033d1501389796-2010-camaro-head-lights-dsc02298.jpg)
![Name: DSC02297.jpg
Size: 36.9 KB](https://www.thirdgen.org/forums/attachments/body/375034d1501389796-2010-camaro-head-lights-dsc02297.jpg)
1 Post
Engine: 2002 SS LS1
That Looks good. Where did you get the headlight covers? How much was involved inputting the suburban projectors in?
I made the headlight covers. To get the headlights in I had to carve out much of the fiberglass headlight bar to get the headlight and adjustment mount to fit.
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
A 69 RS Hidden headlight front end would look good if made properly. Just my opinion though.
Car: 1989 Camaro & 2005 Silverado
Engine: 305 TBI & 5.3 Vortec
Transmission: 700R-4
I dig yours more than the E36 headlights. Nice touch on the covers and the white parking lights.
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
Have you ever sold any of the headlight covers? I've looked into the GTS ones but have heard alot of people complain and have had them fly off
#42
1 Post
Engine: 2002 SS LS1
I wish you would sell a few more. I bought some made by "Wade" and they suck. Huge gaps on either side. I may try to use them as templates to make my own but I'm not the greatest at making things that need to look nice when I'm done.
#43
![](http://i702.photobucket.com/albums/ww25/Uncle_Slappy/DSCF0047-1.jpg)
#44
Car: 1986 Trans-Am
Engine: 305 5.0 TPI
Transmission: 700 R4
Axle/Gears: 2.73 posi
I think the 2010 lights would look good. It probably will be expensive though.
