Cleaning up under carriage
Wanting to clean up the underbody is there anything I should take off before sandblasting. Not worried about the exhaust it is getting replaced any way. Will the break lines and such hold up if they are not rusted?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Cleaning up under carriage
the thought of sandblasting ? forget about it . too many things to protect , low pressure steam/power washer would be best . break ? lines might be o.k. , brake lines would not . clean the underside , then inspect all you can see . best choice would be to have it on a lift to do this . good luck .
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
All I did was when i swapped out my tranny i took a wire wheel to the underside to clean of the undercoating(not much rust under mine). And then i spayed it with black Rustoleum paint. looks BTW did this while the cars was on cement blocks so a lift if you have acess to one makes life a lot easier.
Hotrodboba400
12-10-2019 07:07 PM
sailtexas186548
02-17-2017 03:07 PM
