Bad Bondo job?
Old 09-15-2009 | 06:23 PM
o311stud's Avatar
Bad Bondo job?
i was wandering if anyone has ever seen this before and if so how to repair it. its on a camaro i just acquired. The spot is located on the rh QP right above the tire. Any suggestions are helpful.
THanks in advance
Lance
Old 09-15-2009 | 06:27 PM
Twin_Turbo's Avatar
Re: Bad Bondo job?
Take it down to bare metal to see what's under there. It's not looking pretty
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: Bad Bondo job?
Can't tell how much is filled. Get a better picture and sand.
Old 09-15-2009 | 06:29 PM
o311stud's Avatar
Re: Bad Bondo job?
i can see the metal underneath it looks ok just a little surface rust. but it really makes me wonder what the guy was trying to bondo
Old 09-15-2009 | 06:39 PM
Ethan91's Avatar
Car: 1991 Camaro Z28
Engine: 6.2L LS3 to come
Transmission: 4L60E LVL2 700rwhp
Re: Bad Bondo job?
I've seen it before, looked exactly like that. There was about 1/4th inch of bondo under the surface filling a large dent.
Old 09-15-2009 | 06:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Bad Bondo job?
all of the above , bondo/body filler is a good tool . but , should be used only for minor dings . surface prep. is a big thing , putting on too thick is a big thing , too much hardner is a big thing . clean it all off , smooth out bare metal is best you can . i assume you are going to repair yourself . ask some friends for advice . do some research on body repair , don't get in a hurry . most work can be done with common hand tools . just take your time and do it right . there is never enough time , but always time enough to do it over . good luck .
Bubbajones_ya
07-06-2024 09:32 PM
92firebirdguy
09-01-2016 08:53 AM
83 Crossfire TA
01-03-2016 02:26 PM
Vojtush31
10-11-2015 02:07 PM
m00n420
09-11-2015 03:39 PM
Quick Reply: Bad Bondo job?
