'85 t/a fenders on '91 t/a
Old 09-13-2009 | 08:51 AM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, well after tooling around with my 91 trans am, I found out that there unfortunately is some rot on the driver's side fender hidden underneath the ground effect. I haven't checked the passenger side yet but I'm assuming its the same story. So I was thinking rather than doing a patchy bondo job (forget me welding), I'd just replace the fenders. I really like this fender off of an '85 trans am since it has that little "gill" behind the wheel. I understand that I might need to drill holes into the fender to mount the ground effect but is there any other work that's involved or should it be a direct bolt-on? And what years total did they make that fender with the "gill"? All I'm aware of is '85.
So I was thinking this:
On this:
What do you guys think?
Oh and random question: are thirdgen camaro fenders the same?
Old 09-13-2009 | 05:21 PM
Engine: LB9
Re: '85 t/a fenders on '91 t/a
bumpity bump
Old 09-13-2009 | 05:32 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Fenders had the 'vents' from 82-90 trans ams, non gta's and all firebird fenders should be interchangable (direct bolt on) aside from the gfx work which you already know about.
Old 09-13-2009 | 05:51 PM
Engine: LB9
Thanks!
Old 09-14-2009 | 11:37 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
yep, its a direct bolt on.
Old 09-15-2009 | 03:26 PM
Engine: LB9
Thanks! Nice car by the way. So do you mean that the GFX are direct bolt ons too?
Old 09-15-2009 | 08:22 PM
Orinackra's Avatar
oh... no sorry the gfx arent. The 91-92 ones line up right at the ridge on the fender, and you have to drill holes, and fill the old ones. Heres a pic of my old car, you can see where the stock holes are compared to where my gfx sit.
Thanks for the compliment btw!
Attached Thumbnails '85 t/a fenders on '91 t/a-pict0008.jpg
Old 09-15-2009 | 08:38 PM
Engine: LB9
Oh gotcha, eh that's not bad at all. Some bondo will easily fill those holes. Looks sharp. So that one is a different car? Looks the same as your gray one apart from the paint and rims.
EDIT: Oh oops I didn't notice the t-tops on the red car. So what happened to it?
Old 09-15-2009 | 08:52 PM
Orinackra's Avatar
thats exactly what I did. Put some putty over it, and sanded it smooth.
The red car was rotting apart underneath, so I bought the hardtop car (which is also kinda red) for 125$ that everything was trashed on except the body. So I just swapped all my parts onto it and sent the t-top body to the crusher. And I do mean ALL the parts haha.
Old 09-15-2009 | 09:14 PM
Engine: LB9
That sucks, I hate watching these cars get wasted because of rust. I'd rather see em die with dignity in a fiery crash right after whooping a rice burner's ***!
Jorlain
Exterior Parts Wanted
06-30-2017 12:04 AM
jovibuilt
10-18-2015 09:12 PM
2012sergen11
10-13-2015 08:38 PM
BrianChevy
Wheels and Tires
10-13-2015 01:33 PM
Aaronv808
Members Firebirds
09-30-2015 01:55 PM
Quick Reply: '85 t/a fenders on '91 t/a
