Help identify these parts
Old 09-10-2009 | 01:16 PM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
I have extra parts laying around, can you help me identify where they go and what they are for? Off an 86 camaro.
1. there are two of these, mirrors of each other
2. the other side of the above one
3. is this bent from factory?
Old 09-10-2009 | 01:57 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Re: Help identify these parts
The first 2 go to the headlight panel. The headlight panel might be "stuck" or bolted to the front fascia. One of those brackets is stamped with an L the other stamped with an R for left and right. The driver side being left. The brackets bolt to the top of thr radiator support. There is a triangle side of the bracket with a slot in it. That "triangle" has a flat side sits almost parallel to the fender. The bracket gets bolted to the center of the radiator support almost in line with the inside lines of the headlight buckets on the fascia. As for the last pic I can't help you I never seen a bracket like that. But it looks bent from the pic. I'm gonna take a stab and say it might look like a cruise control bracket but I could be wrong.
Old 09-10-2009 | 02:16 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
It's a little hard to tell because of the angle that picture was taken at but I think the last item is the piece that attaches over the gas pedal.
Old 09-10-2009 | 02:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Bottom pic is the hood latch support brace.It also bolts to the headlight bar.
Old 09-10-2009 | 03:36 PM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Ahh yes, that is correct!
Old 09-10-2009 | 03:37 PM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
Fantastic, thank you they are now where they belong
LT1Formula
20
11-14-2015 01:02 AM
Linson
08-21-2015 03:12 PM
armybyrd
08-17-2015 09:59 AM
GVMV
Exterior Parts for Sale
08-16-2015 08:08 PM
1nastygta
08-08-2015 08:38 PM
Quick Reply: Help identify these parts
