(Was To Be) Turbo Firebird Hood.
Old 09-09-2009 | 11:00 PM
Cambird Z/AM's Avatar
Car: 1991 GTA Trans AM
Engine: 305 TPI V8
Transmission: 4-Speed Automatic (700-R4)
I have a 1989 Firebird with the WS6 Handling Suspension. It is not a Formula, I De-coded the car as a Firebird.
Anyways, it has the Turbo Hood, like the one on the older 1980-1981 Turbo Trans AM's.
I was woundering if anyone knows what the kind of Firebird the Hood came off of and which years. And If there is anything to block off the hole that the Bump leaves.
Old 09-10-2009 | 02:21 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: (Was To Be) Turbo Firebird Hood.
First of all, if your car has WS6 it is a Formula. You couldn't get a regular 1989 Firebird with WS6. It sounds like you've just got the regular stock Formula hood. Those hoods were used on 82-84 Trans Ams and 87-92 Formulas. There should be a block off plate on the back side of the bulge.
Old 09-13-2009 | 01:56 AM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Usually called the Power Bulge hood. As said above, 82-84 Trans Am and 87-92 Formulas.
Old 09-13-2009 | 11:44 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Since your car is TBI you can get an 82-84 T/A air cleaner and a little mechanism that allows the car to get air out of that hole. Mine had the block off plate and I removed it. To me it didn't look like it was keeping water out, plus I never drive in the rain so now it's a heat extractor.
As said before the only way to get WS6 is with a formy. If your car really isn't a formy then the WS6 stuff might have been added by someone else.
bjpotter
01-22-2019 01:27 PM
Dialed_In
08-20-2015 02:45 PM
PestilenceIV
08-20-2015 03:33 AM
Randomtask2
08-13-2015 02:57 AM
antares57
08-06-2015 08:47 AM
Quick Reply: (Was To Be) Turbo Firebird Hood.
