Front Bumper
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Front Bumper
I'm wondering where to get a new replacement piece for the front bumper. It's a plastic piece that's bolted to the bottom of the front bumper that runs up into the car. It's pretty beat up just wondering if I can still get it new some where for cheap or can I just remove the whole panel and be ok?
Car: 1987 Trans Am
Axle/Gears: 2.73 posi
Re: Front Bumper
Are you talking about the piece that directs air into the radiator? Because i'm pretty sure you can get one from year one or classic industries.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Front Bumper
He may be talking about the little skirt/skid plate right under the bumper which attaches to the front of the bumper and directs air towards the air dam which is located under the radiator.
Car: 1988 Trans Am GTA
Re: Front Bumper
Sometimes if you check different body shops they can order parts for u. i have one that i use to get parts. i just bought the bumper piece behind the plastic, he ordered it they wanted $100 for it and he charged me $120 but it was easier than hunting one down. just a thought
Car: 89' IROC-Z
Engine: LO3
Re: Front Bumper
Front Bumper Removed
Re: Front Bumper
No, not the front air dam. It's a plastic piece that runs the width of the "chin" under the front bumper it's bolted down with about 3-5 bolts. I thought I could unbolt it pretty easily but it runs up into the car towards the radiator.
Re: Front Bumper
I took a picture of it. It's the plastic panel that is bolted down. What is this piece called exactly?
Car: 89' IROC-Z
Engine: LO3
Re: Front Bumper
Unsure, maybe bumper skid plate..haha, IDK? I plan just to have one made from sheet metal, give it a nice brushed look. Mine is all messed up, only 1 bolt on each side is holding it on.
P.S. Look up the Japanese blue IROC, he has a nice underneath where he used sheetmetal to make small plates along the underside to smooth it out. I plan to do this also. Way down the road after my front end is complete.
1992 Trans Am
05-10-2023 07:19 PM
