Latest and greatest place to buy replacement panels?
Car: 85 Sport Coupe Camaro
Engine: 1969 Camaro 350
Transmission: TH350
Axle/Gears: 3.73 Posi
So I've been out of the Camaro scene for a while. I'm working on restoring my 85 Camaro and I'm in need of some parts. It seems Classic Industries is now slacking on replacement part offerings and after some searching on the web I have not been able to find some parts. Looking for some help. The list below is everything I need, some of which I've found on Classic Industries as well as Eckler's Camaro. The bigger issue is the door skin/shell. No one seems to have them anymore. All you can buy now are the lower sections of the door, but not the entire skin/shell.
The List:
RH Quarter Panel (Classic Industries, $99.99)
LH Quarter Panel (Classic Industries, $99.99)
RH full length floor pan (Eckler's Camaro $274.99)
LH full length floor pan (Eckler's Camaro $274.99)
RH Door Skin/Shell
LH Door Skin/Shell
The List:
RH Door Skin/Shell
LH Door Skin/Shell
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Latest and greatest place to buy replacement panels?
Don't know about your area, but around here (NC) Camaros are a dime a dozen. I see alot of them for sale in Craigslist for $500 - for those prices maybe you could get a whole car off Craigslist or something and cut out what you need.
Transmission: TH350
I thought about buying a whole car a 1992 Z28 to use as a shell. However I have so much freakin work into the one I have now with the interior and all. I'd rather not mess with doing that all again if I don't have too. Plus that and everyone seems to want at least $4k for a decent Camaro (would love to find one with a blown 350 TPI)
Car: 1986 T/A
Axle/Gears: Stock
http://www.camarocentral.com/category_s/331.htm
A buddy of mine was looking at these and asked if anybody had tried/used them on the boards. Heres the thread:
https://www.thirdgen.org/forums/body/531675-i-found-these-door.html
Good Luck
Good Luck
Hi Mike,
We have ton or resto parts for your Camaro. We curently do not carry any sheet metal,but that will probably change down the road.
Here's a link to the Camaro section of our site if you would like to check it out.
Chevy Camaro Parts
Chevy Camaro Parts
We always have good used doors and and get other body panels in quite a bit. We also have plenty of other parts you might be interested in.
Transmission: TH350
Good Luck
Good Luck
Hi Mike,
Chevy Camaro Parts
Chevy Camaro Parts
Thanks for all the suggestions/comments guys!
Car: 89 RS
Engine: 2.8
x2 on the donor car. That is what I did. I will admit its not easy to cut out floors and rear quarters, but it can be done. If you can find a rust free car and can cut out the metal, its not a bad alternative. However, if you have the $, its much less hassle to buy replacement parts. Even if you have to finesse them to get them to fit.
Ghettobird52
07-06-2024 12:18 AM
1992 Trans Am
08-09-2015 05:32 PM
