Windshield seal - Is it supposed to go all around or just overtop and sides?
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hey guys,
Trying to waterproof my trans AM and I've got a leak thats filling up the front driver(USA passenger) floor when it rains. I read somewhere that there's a seal that rots and can let the water in, but i dont know what its called. I also noticed my windshield rubber seal starts at one side goes around and over the top and down the other side, should this be a complete circyuit or just 3 sides of the windshield?
Re: Windshield seal - Is it supposed to go all around or just overtop and sides?
Thanks mate.
Do you know what the supposed seal is called between the firewall and outside world that would be causing water to pool under the front carpet?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
1 Post
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
i woul d check and make sure about the heater core or hose to the core. you might have a leak there. how often do you have water there is it all the time or just when it rains you might have to pull the carpet check everywhere before you start buying parts you dont need just to help keep the repair at min. cost
Car: 86 T/A
Engine: 5.0 TPI
Hey guys,
Thanks for that guys.
I'll check out the cowl well and go from there, it only happens when it rains so maybe thats it.
The heater is disconnected, not much use for it here in Oz.
I'm ordering all the targa seals and everything from hawks....along with my ls1 mount kit :P so i'll get it all back to shiny new in the roof section then see how it goes.
1992 Trans Am
05-10-2023 07:19 PM
