Body parts swap question
Car: 1982 Camaro
Engine: currently 305
Transmission: th700r4
Axle/Gears: 3.08
I have an '82 berlinetta coupe camaro
I know as well as all that the front nose cone (or front bumper), along with the rest of the car, looks quite ugly compared to the z28's w/ ground effects and such.
since i already have the z28 hardware installed (ie 5.0 305 motor and tr400 trans from an '83 z28) i figured i sould seek out and change to body to look like a z28 too.
My question is will i have trouble mounting the z28 style front bumper and corresponding ground effects kit on my coupe? will modification be required?
anyone with knowledge or experience w/ this sort of job is needed!
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
sniper
sniper
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: Lots of 'em
Re: Body parts swap question
I've never even owned a Berlinetta, or seen one in person for that matter, but I'm pretty sure the front bumper would mount in the same spots, but the ground effects are a different story, there's some funky rod mounting for them, that's welded to the frame I believe.
Car: 1987 Trans Am
Engine: LQ9/L92
You will be able to mount the front bumper, but you will have to find a way to weld on the mounting brackets for the side skirts. Otherwise, everything can be swapped over.
Car: 1982 Camaro
Axle/Gears: 3.08
thanks for the replys
on another note, are the front bumpers all one piece or do they have multiple sections? (on the z28)
Car: 1982 Camaro
Axle/Gears: 3.08
i found the front bumper used for around $150 online, but the front ground fx for it is like $300 some, i hope it still looks good without it
