Iroc Grill and fog lights
Old 05-20-2009 | 12:43 AM
OddJack's Avatar
How hard is it to switch from RS grill to iroc style grill and install the fog lights? Are the wires and mount already there?
Old 05-20-2009 | 12:49 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: Iroc Grill and fog lights
Removing the RS grill and installing the Iroc grill and fog lights are just a matter of a few screws and bolts, I've done it myself. The wiring I haven't done yet, I haven't found a foglight switch for them yet, but I would imagine it can't be that hard to do. Do a search on foglight wiring on here, I'm sure there is a thread about it somewhere. Good Luck!!
Old 05-20-2009 | 01:27 AM
OddJack's Avatar
Thanks...How about the light mounts or holes? They're already there you had to make one for each light?
Old 05-20-2009 | 01:40 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
There are holes allready drilled for the stock foglight brackets. If you are using aftermarket foglights you will either have to drill new holes to mount the lights to or make a bracket to attach to the foglights and then to the existing holes that the factory foglight brackets mount to. I created my own brackets for the aftermarket foglights to mount to that mounted to the existing holes so that they would be roughly in the same position the factory foglights and brackets would be.
Old 05-20-2009 | 02:15 AM
OddJack's Avatar
This helps alot. Thanks Jason for the info!
Old 05-20-2009 | 05:23 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
jaridjohn
07-08-2024 04:49 PM
Frozer!!!
01-19-2024 05:55 PM
mustangman65_79
08-12-2015 07:39 AM
mustangman65_79
08-11-2015 04:17 PM
Omega
08-10-2015 01:46 PM
Quick Reply: Iroc Grill and fog lights
