What is the most ghetto thing you've found done to your car?
Old 08-16-2009, 08:37 PM
  #201
Aussie Muscle's Avatar
Re: What is the most ghetto thing you've found done to your car?
The only home mod on my car is a metal bar to hold open the hood, rather than pay a few dollars to replace the hood struts (which was the first job i did when i got it). the po went to the trouble of making the bar quite good, too.
edit: the bar is actually made from the ones that cross the radiator.
Aussie Muscle is offline
Old 08-16-2009, 09:09 PM
  #202
cougar7926's Avatar
Car: '89 Formula
Axle/Gears: 3:23
ive got a camaro spoiler on my '87 firebird, not completely a bad thing but def out of the ordinary from what ive seen
cougar7926 is offline
Old 08-16-2009, 09:14 PM
  #203
cougar7926's Avatar
Car: '89 Formula
Axle/Gears: 3:23
i had seat covers just like that, threw them out the day after i bought the car.
Old 08-16-2009, 11:16 PM
  #204
iggy89's Avatar
Car: 86 Camaro
Engine: 79 350 carbed
Transmission: TH-350
Axle/Gears: 3.73 posi
Mine didn't have anything to bad done. The thing that made me mad is that the previous owner jacked up the car on the wrong points on the side of the car and bent up the fender. Not only that but he did the same to the other side. Also I found it interesting that I found a plug for a trailer attached to the wiring harness in the back.
iggy89 is offline
Old 08-16-2009, 11:29 PM
  #205
y84pauloflondon's Avatar
Car: 87 T-Top GTA
I haven't done anything really to my car, but the previous owner did.......I bought the car back in the summer of 2000(87 GTA t-top 350). He screwed in a brass looking like hook for his god-awfully-big cell phone on the side of the console by the radio. This spring when taking apart the dash and console, I found some EXTRA wires that someone added for something.....All cleaned up now!.....and the hook was gone along time ago!...but the 2 small holes are still there
y84pauloflondon is offline
Old 08-16-2009, 11:42 PM
  #206
TGO - 10 Year Member
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Mines got a jacked pass side fender, and I had a buddy with a bird where the po actually had a hitch installed and used the car to pull his moving trailer
Caveman305 is offline
Old 08-17-2009, 09:10 AM
  #207
Crux's Avatar
Car: 1987 Camaro
Engine: V6 2.8L
Axle/Gears: stock?
Wait..so that hitch on my car isn't stock? O_O
Haha..how many of you wanna transform "PO" to P.O.S.?
Crux is offline
Old 08-17-2009, 10:17 AM
  #208
Caveman305's Avatar
Engine: L03, LB9
Just imagine driving down the road and seeing an lg4 purple firebird pulling a moving trailer
Old 08-20-2009, 01:40 PM
  #209
cutmesomeslack's Avatar
Car: 1984 GMC. soon to be 1986 camaro
Engine: Carb'd 350
Transmission: TH 350
Axle/Gears: Stock
[quote=JHave you ever tried to ride 2 miles on a chopped 3-speed bicycle with a banana seat, sissy bar and Monkey Hangers with two bags of fiberglass insulation tied to the sissy bar?[/quote]
lmao hahaha
cutmesomeslack is offline
Old 08-20-2009, 11:42 PM
  #210
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Okay heres my list:
54 self-tapping screw holes in the doorskin (for the slide hammer to pull the door back out to shape) with bondo squeegee'd through them and another half gallon of bondo ontop of that.
LACQUER covering up the bondo
Someone replaced just 1 shock on the back (because he cut through it with a sawzall accidentally)
STP Brand oil filter
2 mismatched truck tires on the back and 2 mis matched car tires on the front
Stick pins holding the headliner to the backerboard
Hatch Pulldown disconnected
Crossflow muffler with holes punched in it
Hood prop rod from some miscellaneous car added...oh and they dimpled the hood with it when they didnt get it pushed down all the way
Extra wiring for good measure that goes nowhere
NatesZ/28 is offline
Old 08-20-2009, 11:52 PM
  #211
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Well, just was doing some work on my 1988 GTA on the passenger side seat (I have rubber tube coming out from underneath and am looking to make the Ultima seats operational) and behold I find a dried-up joint. Imagine that I crossed the Canada/US boarder twice and drove all the way from Chilliwack, BC to Santa Cruz, CA and back!!!
I should also mention that none of the interior lights were working - might have something to do with that aforementioned joint!!
Other Ghetto fixes? Driver's side seatbelt wouldn't retract, so PO gave me one he had ordered from somewhere - obviously not for anything GM!!!!! Don't know how he planned to fit it - big square box for the roof retractor. On the plus side, I did manage to fix the original seat belt retractor.
Finally, stereo that was installed when I bought the car - cracked/broke all of the screw holes in the pod, so it flops around in the hole.
GTA50 is offline
Old 08-21-2009, 12:24 AM
  #212
NatesZ/28's Avatar
Originally Posted by KatsCam
Defense weapon. ROFL!
Board with nail? EN GARDE!
Old 08-21-2009, 12:17 PM
  #213
302to305's Avatar
The most ghetto thing I seen is my brother. he had a 97 dodge intrepid. he would put the cheapest motor oil I ever seen. every time he do a oil change is will smell like burned coffee. He will spray paint hub cap and spray paint the car all kind of crazy color. He will use a t-shirt for a cold air intake and drift in the roads.
302to305 is offline
Old 08-21-2009, 09:26 PM
  #214
cuppiecake88's Avatar
Car: 1988 IROC
Transmission: garbage
it seems an 8 year old did the wiring, the headliner was made of duct tape, the needle on one of the gauges was a toothpick
cuppiecake88 is offline
Old 08-22-2009, 06:34 PM
  #215
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
a toothpick? thank god that the guy i got mine from i live with so what ever i find (which is nothing so far) i get to give it back to him lol with style j/k. lol toothpick
z28 TPI is offline
Old 08-22-2009, 06:53 PM
  #216
Harwood's Avatar
Car: 1985 Pontiac Firebird
Engine: '93 LT1
Axle/Gears: 4:11
Toothpick... that made my day.
Well, I started with a rusty 500 dollar car that I bought b/c I couldn't believe that it started more than anything.
It had a hood scoop. My 4 yr old daughter kicked it off for me. Drywall compound was used to smooth it over.
It had brake cooler air induction. The same size and shape as the cheap fiberglass hood scoop.
The stero was very loose. I didn't want to litter, but I was tempted to throw it out the window when it fell out and started to rattle around the accelerator pedal.
And the wing was raised up to look like a REAL hotrod and was attached with 2x4's... yeah. Wood. Nice. Classy. I loved it.
No underwear tho. Or toothpicks, so... *sigh*
Harwood is offline
Old 08-22-2009, 08:55 PM
  #217
Car: 1988 IROC
ive had this car for about a month so i still find new surprises. today i found that the right rearview wouldnt adjust. apparently the mirror was being held in with paper and duct tape.
the toothpick is now gone
Old 08-25-2009, 12:20 PM
  #218
julian.mora's Avatar
i just got my 3rd gen. sunday day and i am now the proud owner of the first car i've ever owned that plays la cucca rotcha on the horn. wow i don't know what to say, i just want to thank every one who believed in me. we did it.
julian.mora is offline
Old 08-25-2009, 02:06 PM
  #219
Bmv5's Avatar
Car: 1986 Iroc-z Camaro
Transmission: 700r4 Automatic
The PO of my 86 iroc had cut 2 holes out in the dash and had door speakers in them when i bought it. So now im looking for a new dash because this is an ugly p.o.s..
Bmv5 is offline
Old 08-25-2009, 02:25 PM
  #220
Caveman305's Avatar
Engine: L03, LB9
Why not get a set of nice quality speakers with bad *** grills to put in its place, atleast until you get a new dash
Old 08-25-2009, 02:29 PM
  #221
Caveman305's Avatar
Engine: L03, LB9
Also i found on craigslist a really nice convertable rs only problem was it had a firebird dash in it,with an aftermarket speedo in the original location sticking way out, i do like the bird dash but not in a camaro, and it had cool ghost flame paint minus the fire skull grinning with a gold front tooth, sorry if its anyones on here but that was a good paintjob till i saw the tooth
Old 08-25-2009, 07:35 PM
  #222
Car: 87 T-Top GTA
My first love was a 87 Mec Sable. I painted it jet black, limo tinded all windows, red inter lights, Added More red lights under the dash by driver and pass leg area, 2 big moroso stickers on rear window(No Moroso parts on car), had 2 6x9's inside a SHOE box on floor by center console, 2 8" home audio speakers from the early 60's mounted on balsa wood for the rear..........This car was BAD A**............lol
A buddy of mine while camping, set my front speakers (6x9's) on FIRE.....When we were packing up and leaving he spilled some water out of a cup and onto my speakers(i was outside by camp sit/ did not see him spill). So he used his lighter to dry speakers, I came back to the car, he looked up at me and that's when the speaker lit up in flames. He beat the flames ou with his hands and towel......Damn speakers still worked.
Old 09-03-2009, 10:42 AM
  #223
Mudskunk's Avatar
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
i was towing my boat with my 2003 silverado and while parking the trailer i left the tailgate down and cracked out about 15sq inches of the tailgate. its one of the rare pro-tec boxes the same stuff the avalanche bed was made of when they first came out. so i removed the tailgate disassembled the tailgate to get to the broken bits and epoxied it all back together. i then used a airgun as in a toy model painting type airgun to spray touch up paint without a lot of sanding.
at some point i will go smooth it all out when i feel like getting dirty with it and have the proper grinding/sanding tools. but its good enough for now its not relaly noticable unless i point it out or someone gets up close and is aware the damage is there.
as for my firebird... if i even start thinking about *******ing something taht i havent the ability for i go find someone that actually knows and have done right. my truck is a work truck my firebird is my baby.
Mudskunk is offline
Old 09-03-2009, 01:06 PM
  #224
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I bought my car back in 2002 and thought it was bodywork free. I have recently completely stripped it to bare metal to restore it and low and behold, the drivers door leaves me wondering. My side mirror had always wobbled when I hit bumps, and I found that theres about a gallon of bondo at the top of the door! The door is completely smashed. I actually sanded it down back to bare metal just to see the carnage and I have NEVER seen a door that badly dented and smashed. I must say, they did a good job fixing it because I would have never known except for that wobbly mirror!! And it held up the 6 years I've been driving it too!
I also noticed the door was originally red but my car is white, so they replaced the original door on the car with that junk one!!! C'mon guys, all those doors out there and they had to use a completely destroyed one!! I have since bought a REAL dent free original door that will be taking it's place. Other than that, my car was pretty darn clean.
whitedevilTA is offline
Old 09-03-2009, 10:32 PM
  #225
cougar7926's Avatar
Car: '89 Formula
Axle/Gears: 3:23
just bought my car for $800, '87 firebird... cars a REAL project. theres a cork in the breather, cooling fan is rigged to the battery and you gotta twist the wires together to turn it on(wires stick out of the passenger front wheel well), the p/o took all the wires in the engine bay and rubber banded them together, then ghetto rigged almost everything to work. he was very creative but did it all wrong...
Old 09-05-2009, 06:57 PM
  #226
wferon1974's Avatar
Car: 84 camaro rs
Transmission: 350 turbo
I just bought my 3rd camaro and this one is a whopper full of bs the po or the owner before that did to this car. First off let me start out by saying that whoever the mechanical guru was that worked on this car had is riggin skills honed like a dull butter knife. I found a complete throttle body under the hood that was'nt attached to anything at all and was burried under a bunch of spaghetti wires. The bad *** Turbo 350 tranny was resting on a 4 x 4 x 1 inch piece of pine on the tranny mount and held toegther with chain tightened by a carriage bolt. I am sure that as I progress in this project car I will find all kinds of stuff to share with you guys.
wferon1974 is offline
Old 09-05-2009, 11:47 PM
  #227
camarokid89's Avatar
Car: 1984 Camaro RS
Engine: 355 v8
Axle/Gears: 3.08
so im buying my thirdgen and when i go to open the door, the door handle just flops loosely in my hand... i turn back to the owner, to see him running towards the car, he jumps and slides over the hood. as he mounts up to the window he looks straight at me and says (whats wrong? you got your daisy dukes all up in a bunch. jump in through the window),i laughed so hard i was crying. and i still havnt fixed the door handle. and after read some of these i realize im a cheap SOB to, when my door handle broke from the inside i replaced it with a 9/16 wrench.
camarokid89 is offline
Old 09-07-2009, 10:23 AM
  #228
radar1232's Avatar
Car: 1983 Firebird, 1989 Firebird
Engine: 2.8L V-6 2bbl, 305 V-8 4bbl
Transmission: 200C Metric, 700R-4
Axle/Gears: Stock
So here is my story, on what the PO left for me. Mind you I paid $600.00 cash for this vehicle, he wanted $1,000.00 but I talked him down told him what I had on me at the time.
1.) PO left all the emission stuff on car but hooked every single vac line to a tee in the back of the carb which of course made it run like crap, the vac ports he was not using had hoses and bolts in them.
2.) PO has taken the entire headliner out of the car and left all the clips there removed dome light as well as all the mechanicals connecting the lock and latch system on the trunk, so I have to use a screwdriver from the inside to open it.
3.) PO put like a ton of bondo on the hood in two spots and did not let it cure (more than likely would have taken 2 months or more) and painted it with a rattle can, of course paint was chipping right off.
4.) PO rattle canned the entire car without bothering to sand any of it at all so the paint just rubs right off (imagine that paint does not stick to shiny surfaces.)
5.) I swear this is at least an inch of grease built up all over the engine I am still trying to get it off of it.
6.) One word "plywood" for the center console lid.
New things to date:
1.) Sunroof that leaks so he took the gasket material out of it and put roofing sealant all over it, instead of fixing it.
2.) Wiring hacked unde the dash never seen anything like it, all the wires are either white green or black makes me think of a/c wiring when i look at it.
And that is what I have found so far. Here is a pic of the Wonderful sunroof sealing:
Attached Thumbnails What is the most ghetto thing you've found done to your car?-dscn1097.jpg
radar1232 is offline
Old 09-12-2009, 05:20 PM
  #229
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
in my old 83, the carpet would get soaked when driving thru puddles, i ripped the carpet out, and i found beer cans cut into square sheets, and bondoed to the rusted out floor pans. pretty gehtto floor patching job.
iroc a 86 berli is offline
Old 09-23-2009, 11:21 AM
  #230
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
thats awesome, David Hasselhoff slides over the t-tops. thats pretty impressive. poor David http://www.youtube.com/watch?v=QH3JAp7vMuo
transam85dudeman is offline
Old 09-23-2009, 01:07 PM
  #231
Christal_Z28's Avatar
Car: 1992 Camaro Z28 Heritage Edition
Engine: 5.7L 350; check out my VGarage :-)
Transmission: 700-R4
Hm... my '92 RS was in near mint condition when I bought it from a PO a few years back... nothing was ghetto on it, surprisingly.
But when I bought my '92 Z28 back in '03, I noticed the aftermarket Kenwood HU wasn't working, no radio, wouldn't play CDS, nothing. So, I took it out and low and behold! There was probably 1/2 a roll of duct tape used to connect the wiring and antenna! Oh well, common mistake among younger owners, I guess.
Christal_Z28 is offline
Old 09-23-2009, 02:51 PM
  #232
Pie
Pie's Avatar
Car: 89 Camaro RS
Engine: 383 Stroker in the works
Transmission: TH-350 Auto
Originally Posted by chas0218
Mine too! but all the wiring under the hood is a cob job. I dont want to tackle it but i have no choice b/c it erkks me to no end.
Mine too... the guy just hacked stuff out of my car, a/c, choke on the carb... and the wiring is a nightmare. Had to hotwire the headlights to make them work for now, the guy took out the computer, or whatever is wired next to the fusebox below the drivers side dash, and the guy wired the fusebox himself.. the radio backwards.. just a bunch of hack jobs in my car.
Pie is offline
Old 09-23-2009, 03:09 PM
  #233
solaris_vii's Avatar
Car: 1997 z28
Engine: lt1
Transmission: t56
my 85 iroc was actually in great shape when i got it.... my 85 vette on the other hand is another story. the timer to turn the interior lights like a minute after you shut the door broke (guess its a common problem on c4s) and the previous owner decided to take out all of the bulbs in the car rather than just change the time and broke damn near every single plastic trim piece in the process. not only did i have to replace the bulbs and the timer but im still hunting down trim on ebay!
solaris_vii is offline
Old 09-23-2009, 04:17 PM
  #234
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Well my camaro had a real ghetto moon roof cut into the top. I was gonna weld a sheet over it. but i kind of like now and gonna have i guy i know ( who does really nice sun roofs and such) redo it for me.
Iroc-Z28Man is offline
Old 09-23-2009, 06:51 PM
  #235
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Axle/Gears: Stock / 4:11 Moser 9"
a parts car i bought must have previously been owned by a contractor. where the air dam should have been there was a piece of drywall "installed" in it's place. the car also had a lot of timing issues. turns out there were two drywall screws holding the cap on the distributor. i don't know how or why, but he had the screws going inside the cap and the rotor was arcing on the screws. it was a complete mess.
battmann is offline
Old 09-23-2009, 08:54 PM
  #236
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
My 86 wasn't too bad. But whoever did the radio was f'ed up, when I got the car the wiring harness and ANTENNA connector where cut out. NOT cool. And the heater core leaked, so instead of spending $30 on a core, lets just not hook it up and leave coolant in it. Until I fixed it almost every time I stopped I would get coolant on the block. Scared the crap outta me, thought the head gaskets were leaking. The alt was also the wrong kind, they hardwired it in and it was a 60amp alt.
None of this is as bad as my bird, but the hood prop was the best. 1x2 with a big rusty nail in, PO (older hillbillie) said he used it for self defence when it wasn't holding up the hood.
novafirebirdguy is offline
Old 09-23-2009, 09:23 PM
  #237
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Originally Posted by 5678TA
on my TA, the PO had a 2x4 drilled onto the clutch pedal cause she was short.
Haha, I can't get far enough away from my clutch pedal in my trans am... my knee rubs the bottom of the dash and my foot gets hung up under there.
zraffz is offline
Old 09-23-2009, 09:49 PM
  #238
92purplehaze's Avatar
Car: 90 IROC-Z
Transmission: M6
Axle/Gears: 9" spooled 3.70
lol that is someone on here
92purplehaze is offline
Old 09-23-2009, 09:59 PM
  #239
GeneralLC's Avatar
Car: 1987 Camaro Sport Coupe
Engine: None
I attached my $50 3" cone K&N Airfilter directly to the MAF with duct tape and what previously attached the MAF to the air dam box.
That and I use a piece of wood to hold up the hatch and hood. The piece of wood also has a nail in it for good measure.
GeneralLC is offline
Old 09-23-2009, 10:17 PM
  #240
cheveylover's Avatar
Engine: 305TPI
Axle/Gears: 3:08...
i found my car had the wrong nock sensor and to top it off it was wired to the fan relayand the other half of the wire was just hangin out
cheveylover is offline
Old 09-25-2009, 09:20 PM
  #241
yanke1's Avatar
Car: '91 Z28
I have a 91 z28 305. Had to replace the computer and found that the PO had put in a 3.1L memcal with a 5.7L hypertech performance chip, What were they thinking?
yanke1 is offline
Old 09-25-2009, 10:38 PM
  #242
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
Lots, and lots of duct tape to cover the holes that were punched or smashed into the vent ducts in the center console. . . bits of 2X4's to keep battery in place. . .And rusted 2 1/2" inch long screws drilled through the headliner to keep it up against the T-top. . .
Guy In A 90 RS is offline
Old 09-25-2009, 11:06 PM
  #243
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
when i originally bought my car there was bad boy stickers all up the side and speakers drilled into the floor... nuff said... haha
C-Titan is offline
Old 10-04-2009, 09:18 AM
  #244
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Hmm..besides needing to set mouse traps up in my car....Someone used tie wires to hold the hood inserts onto the hood of my car. They actually drilled tiny holes through the inserts, put the wire through the holes on one side then back through on the other side, then they ran the wire through two holes on the hood and twisted the wires together with pliers. The inserts would sort of "float" above the hood, as I drove down the highway, the wire being the only thing preventing them from flying away.
https://www.thirdgen.org/forums/body...ting-hood.html
New2Chevy is offline
Old 10-04-2009, 09:56 AM
  #245
z-man92's Avatar
Car: 1992 Z28 Vert. 1 of 1254
Transmission: 5-speed manual
Axle/Gears: 3.08 posi
Here's "Rich-boy" ghetto....
Trailer hitch on a 5-speed vert.... who does that?!?!?
My 92 Z28 convertible came from the grandson of a really rich guy (won't mention his name or company here) who got it from 'ole grand-dad as a college graduation present (nice present!). First thing I had to do when I got the car was to remove the damn trailer hitch on the back! The kid actually used the car to tow his jet-skis to the beach. DOH!
z-man92 is offline
Old 10-04-2009, 05:37 PM
  #246
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
ha ha ha....whatever works I guess.
Old 10-05-2009, 12:38 PM
  #247
settle down there "capitan caps lock".
there are people on this site with functional trailer hitches. one guy tows his racing wheels and tires to the autocross track i believe. i dont think its considered ghetto.
Old 10-05-2009, 02:26 PM
  #248
Engine: 350TPI/ S50
I've seen nicer cars with trailer hitches. Theres a old guy around SW PA with a real nice First Gen camaro all arbrushed and stuff with a trailer hitch. his trailer is a another first gen cut in half from the back of the doors. It actually is a really nice combo both pieces are painted the same.
Old 10-05-2009, 08:24 PM
  #249
z-man92's Avatar
Capt Caps lock?!?! Where does that come from and what does that mean? I don't know you, you should have some respect before you start calling people names.
I'm not doggin' trailer hitches on cars, but when you put a trailer hitch on a car that is already structurally inferior to a hardtop because the original hardtop was cut off, it's not just ghetto, you are an idiot in my book. That's why GM would only put up to a 5.0 liter in the convertibles, because of the torsional twisting issue already. Plus without the huge back window on the coupes that weighs a ton, I would think the rear end could get squirrely easier. I don't have my owners manual, but I can about bet GM did not recommend towing stuff with a third-gen camaro convertible.
Hard top...fine.
z-man92 is offline
Old 10-05-2009, 08:25 PM
  #250
z-man92's Avatar
Just what I was talking about in previous post.......... Convertible fellas, not coupes...little light trailer, maybe OK, even with a vert .... but double "jet-ski" trailers weighing half of what the car does being backed into the lake on a wet ramp -
I DON'T THINK SO!
Now with that said, everyone sit down, sing a verse of "Kumba-ya" and relax!
z-man92 is offline
Quick Reply: What is the most ghetto thing you've found done to your car?
