Anyone know how to get pk2 primer off your hands
Car: 87 trans am
Engine: 305 tpi
Transmission: auto unfortunately
I was painting my truck and um well my hands are pretty much covered in the pk2 primer. This stuff wont come off!!!! Ive tried everything to get it off but the only thing that works so far is to peel it off. Ive tried laquer thinner, mineral spirts, Goof Off Extreme. the reducer it cam with, simple green, and the pumice orange stuff. anyone know of a way to get it off???
At least i know this stuff will stick good.
Its a high build urethane primer
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Anyone know how to get pk2 primer off your hands
I've seen Gasoline eat through some serious skin stains. 75% chance it'll work. avoid the fumes... ventelation... safety... etc.
Are you in Bad Axe, Michigan? I've got a place in Port Austin.
Car: 87 trans am
Engine: 305 tpi
Ya i live right in town, ill give the gas a try im only out a layer of skin
Car: 87 trans am
Engine: 305 tpi
well gas didnt work ill just keep picking at the stuff till it all comes off, Maybe a hot shower hmm
Car: 87 trans am
Engine: 305 tpi
Well while i was in the shower i found out that ive got a TOUCH OF GRAY in my hair, Owell i found out something that kinda takes off the primer your razor that you use to shave with i was using it kinda like a patao pealer on my hands works better than biting at the stuff, maybe ill trie the orbital sander with like 800 grit. i wont have any finger prints for a while i guess.
Car: 86 T/A
Engine: 5.0 TPI
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Homie that stuff is TOUGH... thats why you wear gloves when you mix paint...okay okay sorry
I had POR 15 spots on my arms for MONTHS lol
scrub the paint with the corner of some 600 grit wet/dry under running water...comes right off...all you have to do is give the reducer /acetone something to get underneath it. Brake Cleaner works wonders...I do NOT advocate this, since it causes cancer in california. but it does have lots of yummy solvents
