Budget enamel paint job flexability? Also Clear Coat?
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
On the plastic bumpers that flex how would the budget enamel paint job hold up to this? Is there a flex agent you can use?
Also has anyone used a clear coat on top of the gloss paint?
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Budget enamel paint job flexability? Also Clear Coat?
It holds up great without the flex agent. I've had no problems with mine at all. From what I've been told the flex agent is only used when the bumpers are painted off the car and installed later.
There is another guy here that sprayed clear over his implement paint and it came out looking great.
Mathius
ambainb
04-25-2016 09:21 PM
