Repaint, I need the original codes!
Old 02-10-2009 | 02:27 PM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
I'm repainting my teal 1992 Camaro. Last owner attempted this, and did a bad job, there are runs around the wheel wells and some mismatching colors that are hard to notice.
I need the exact color from the factory.
All I know so far is that it is "Dark Bright Teal" and WA # 9238 Code 37. What is the bodyshop going to need to reproduce it? One fender looks to be the exact color... maybe use that one for the whole car? What do I do?
Also, I would like to know how many clear coats the factory paint job had.
Thanks!
Old 02-10-2009 | 09:39 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Re: Repaint, I need the original codes!
Just tell the paint shop the model and year of car and they should be able to look the code up.
Old 02-10-2009 | 09:43 PM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
Look it up on www.tcpglobal.com It is Dark bright Teal poly as you said, these are the codes it lists
4300
37
9238
Old 02-10-2009 | 10:26 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Thanks!
You have all the necessary information to get paint mixed. Are you having a shop paint your car or just mixing paint for you?
When the shop looks up the code it will give them the formula to mix the color. But all it takes is 1 small drop of color, 1 drop too much or 1 drop to little, to change the color . If you ... or they are shooting the color it should have some sprayed out on a test panel and compared to the paint on the car to check for a good match. If at that time it need tinted to match it can be done with more of the same tinting colors that were used to mix it.
As far as the number of coats of clear the factory used originally, it's hard to say, because the factory does things different than we do in the repair business and the materials are completely different now than what was used when your car was built. At the shop were I work we typically use 2 coats of high solids clear on the cars we repair.
Old 02-11-2009 | 12:10 PM
Thanks, I am having a paint shop mix, and paint the car. I have no expertise in painting, and I don't the equiptment. I'm looking at a respray, and the car is already teal so I don't think they'll have to remove much, or do the door jams, etc. Probably just do a lot of taping. What would that cost? I mean I want it to look good, but I don't want to spend a ton of money. What's this going to cost to match and do a basic, "factory quality" respray? Under $2,000?
Old 02-11-2009 | 08:56 PM
Car: 86 T/A
Engine: 5.0 TPI
I can't tell you what it's going to cost in your area. Here $2000 wouldn't quite cover a nice job, but we tend to remove everything that touches the paint and do a high quality job. We won't do a lesser quality job even at the request of the customer. Our name is on it!
Old 02-11-2009 | 09:26 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
so if someone brought a car to your shop in pieces and all body work was done and there were no trim pieces or masking involved would it still be the same price?
I would think it would be at least a little cheaper if the car had no weatherstriping,doorlocks,etc.?
Old 02-11-2009 | 09:34 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
you can do it yourself for about that
i know some people dont have the tools and yes sometimes a shop to do it is better.
luckily my grandpa has great painting skills to.. hes done over 15 complete restos on older cars (1920-1950) and he's won "best paint" from major car shows in indiana and illinois numerous times. car shows like "goodguys" "nationals" etc. its good to have a master car builder in the family. besides me that is hahaha jkjkjk
Old 02-11-2009 | 09:46 PM
you and grandpa must get along pretty good huh?
Old 02-11-2009 | 11:50 PM
Car: 86 T/A
Engine: 5.0 TPI
I was talking about quality not cost. He was talking about having everything masked off. Thats not the quality we shoot for. At any cost. In your hypothetical situation the cost could be less than normal. But in all actuality normal is more than double what he was hoping to spend.
I really wish I could help everyone on here paint their car. In person. It's such a satisfying feeling to accomplish something like that. With a little knowledge and some basic tools you can get professional results. But jumping in with both feet and no knowledge of what you're doing isn't going to get you the finished product you desire. Especially on the first try. A little practice goes a long way ... I guess we all have to start somewhere.
Old 02-12-2009 | 11:43 AM
I was hoping it'd be under $2,000, but I could go up to $3,000. That would be as much as I'd be willing to pay but I've seen some really nice paint jobs in the TGO "What color to paint" board that were had for well under $3,000. What does your shop charge for a quality paintjob, with the prep work and removal of panels, etc? I would think it would be similar to what I would be charged here in Wisconsin.
Vintageracer
01-10-2020 06:33 PM
Cornholio7979
09-20-2018 03:31 AM
deracer
04-11-2016 01:04 AM
lee01
04-09-2016 02:56 PM
3tas4me
09-04-2015 02:45 PM
Quick Reply: Repaint, I need the original codes!
