Changing 87 trans am wing to 91 trans am wing
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Whats all involved? I havent pulled the 87 wing off but the dside of the wing has an adhesive caulk running along it so either the rubbr split or the tab or tabs broke. I dont want to switch to the 91 hatch with the brake light in it. Can I modify my 87 hatch clips to fit the 91 wing? thanks
Car: 89 Trans Am
Engine: 305 alive
Transmission: slugomatic
Re: Changing 87 trans am wing to 91 trans am wing
Actually I'm doing the same thing. I took the rubber wing off and put the fiberglass one in its place. You will need to redrill the holes and fill in the existing holes. I need the little clips to install the fiberglass spoiler. so i can go on.
Car: 1990 Corvette
Transmission: ZF6
Axle/Gears: Dana 44 3.33 ratio
hi !
i will do the same job in a few days so i will need the same hardware than you but i don't know what are the little clips we need to do it.
i want to install the 91 hatch trim on my 86 glass but i have some questions:
_ can i use the original brackets on the glass frame ? (the brackets used with the rubber wing to attach the tips.)
_ have you got a picture of this clips ?
_ where can i find it ?
Car: 87 GTA
Engine: 385 sbc
From what I understand. the clips are different. You can get the universal mounting hardware that come with wings that hawks sell and it should work for both styles.
Car: 1990 Corvette
Transmission: ZF6
i find the spoilers but can't find the mounting hardware on their site
could you send me the link please ?
Car: 87 GTA
Engine: 385 sbc
I dont have a link, I was assuming they would offer it seperately. You should call them since they may not have everything listed on their site.
maroe624
04-16-2017 08:29 AM
eightsixseven
08-14-2015 03:09 PM
