Roof Drip rails
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
Roof Drip rails
My car is a hard top and has the black drip rails on it. During the painting process the body shop removed them to do a better job. I know they use double sided tape on the small tabs, but their was also a piece of what looked like weatherstrip between the drip rail and the roof. It was only abut 16 inches long and was located on the drip rail next to the roof directly over the window. Does anyone know what this strip is made of? Is it just plain foam weatherstriping? It is old and dried out.
It did not continue down the roof pillar towards the bottom of the windshild.
Any input would be appreciated
Mike
Mike
Car: 1988 IROC-Z
Re: Roof Drip rails
Sorry James, I added some more info to the post. I would post a photo but I live in the sticks and only Have dial up.............
Mike
Mike
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Roof Drip rails
https://www.thirdgen.org/forums/atta...ion-photo7.jpg
JamesC
Car: 86 T/A
Engine: 5.0 TPI
Re: Roof Drip rails
I've replaced some of that type stuff with the foam tape you put on the bottom of a truck canopy. It was probably in an area that was a little rough or where 2 panels come together. An area that GM new would need a little extra seal. Canopy tape is sticky on 1 side and squishes down pretty well. If thats to thick you could use some strip caulk.
Car: 1988 IROC-Z
Re: Roof Drip rails
Re: Roof Drip rails
It may, but I am hoping the weather stripping will keep the water out.
I am still several months away from having car completed to give a definite answer. Just hanging the door and fenders back on now.
Car: Too many cars
Re: Roof Drip rails
the drip rails are just to divert the water from coming he in the car from dripping off the roof. Water won't come in if the window is up. To me it looks alot cleaner without it, & you don't have to worry about dirt build up. If water stays in their, your roof will start to rust as mines did.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: Roof Drip rails
I left mine on when I got my car painted because I didn't want to damage them taking them off since you there extremely hard to find, but I really wish I would have removed them
gixxer92
05-18-2017 12:20 PM
formula00ra
Interior Parts Wanted
09-28-2015 12:50 PM
