Wheel Locks
Car: 1991
Transmission: 700
Wheel Locks
Hello, I bought a 1991 Chevrolet Camaro RS back on April 20th. The problem is that is came with 16" Boyds wheels. They have wheel locks on them and I don't have the lock. I know most people weld a bolt onto them and then get them off. I don't have acces to a welding unit at all. Is there some sort of ******* way I can do this.
Re: Wheel Locks
Yep, you can call Boyd and see if you can get the lock for the lug nut, or even autozone has these.
But what these are is, a exctractor for lug nuts. Ask at the counter and they should know what you are talking about.
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Wheel Locks
depending on the type of lock nut (mc guard ext), i use a 12 point a tad smaller then the nut and a BFH and beat it onto the nut. the extractors work pretty well for some syles, but not so good on the splined type unless u get the master extractor kit.
Re: Wheel Locks
Yah. Just beat a 12 point socket on the lock lugnut and twist it off with cheater bar. After the lug comes off use a screw driver and a hammer to push it out of the socket. I did that on my '72 Nova. Use a craftsman or snap-on socket and take it back and get a new one if you mess up the teeth on the socket.
Car: 1991
Transmission: 700
Re: Wheel Locks
Thanks for the help guys. I live overseas so It will be a while till I get a 12pt. socket. But that will be my next step.
You guys are great for information I appreciate it.
1 Post
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Wheel Locks
Similar situation. After much drilling, cussing, etc., I gave up & went
to the local NTB, humbly begging for help. "No Problem" said the
the counterman (recognizing me as a loyal repeat customer -- other
stories...), "just take it around back, & Jackson can help you out."
Whereupon Jackson took the appropriate Impact socket (the heavy
black kind), BFH'd it over the lug, and then put the air wrench to it.
Sidebar: If it's that simple to remove them, how effective could
they ever have been as theft deterrents?
Car: 1987 Black IROC-Z (SOLD)
Re: Wheel Locks
Wheel lock are only a problem to the owner of the car. If someone wants your wheels he is going to get them, wheel lock or not. So forget about replacing the locks in the future.
Car: 86 Firebird
Engine: Buick 3.8 V6 Turbo
Transmission: 200r4
Axle/Gears: 3.42's
morrow
01-13-2024 12:29 PM
