Remove Undercoating in fenderwell?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I plan to start doing some rust repair this week on my car. The first spot will be patching 2 holes in my fenderwell. I am wanting to remove the undercoating so it wont catch on fire while I weld. As well, see if there is more rust spots I'm not seeing yet.
Any good tips, advice, chemicals to use?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Remove Undercoating in fenderwell?
mine was thick and dry enough that i was able to bust/pick/scrape it all out with a 1.25 putty knife, no heat or brushes, didnt take long either. It just scratches the metal up a bit, but if you repaint it there is no problem.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
you have to get the proper wire brush....one that is bent towards the ends of the wire so it bites into it....i use this a lot at my body shop....works like a charm...contours to the shape of whatever your doin and cleans it to the metal...
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
ovencleaner, scotchbrite pad, and a putty knife.
did my floor pans yesterday ovencleaner does work spray on let sit 30 sec sand or scothbite it then use putty knife might have to do this 2-3 times
Engine: 350 S-TPI
charged? you got a pic of what your talking about?
redbird, what brand are you using and I'll go pick some up and give it a try.
Car: 92' firebird
I used the heavy duty ovencleaner I think any brand will work
give it a try you'll be suprised
Engine: 350 S-TPI
oven cleaner didnt work for me.
So far I have just been letting it burn while welding.
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
they actually sell a spray on remover that you can get from eastwood. works really well. never tried the oven cleaner method so i cant compare to that though. if oven cleaner doesnt work, you might want to look into that
