t tops
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
t tops
How do i get the black metal pieace connected to my body under the t top off there is rust damage and i cant sand it without removing the pieace does it just pop out? Im trying not to break it
Car: 1991 Camaro RS
Axle/Gears: Factory
Re: t tops
i unscrewed 3 that are visible r the other 3 hidden
Car: 88" Trans am
Engine: 350 bored. 383 Stroker Kit
Transmission: Power Glide
Axle/Gears: 4:10
Re: t tops
mines rusty to, they are expensive to replace. I have t tops also that leaks some times i need to find the most reliable t top weatherstrip for 88 trans am my self.
Re: t tops
there are more than six i believe. i think there are eight. not important though. there are the coners, that will be hidden under the weatherstripping. depending on how much rust damage that is there, you may not find a screw head. when i redid mine almost all of the screw heads were non existant due to the rust. pry bar and vicegrips are your best friend.
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: t tops
New I have seen them for $200 or so, used in good shape on eBay were going for $50+, and I got a fairly decent one (no real deep rust, fine after sandblasting) from my local pull-a-part for $10...
In other words, if you can find a decent one at a junkyard, that will probably be your best bet. Although, it can't hurt to hit eBay for a while, and see if you can't get in on a nice one for a decent price... Good luck!
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
