Hatch Glass Removal?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
How do I remove & installing my back hatchback window.
I want to replace mine by myself; i might be getting another hatchback glass for mine.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Hatch Glass Removal?
Just unbolt it and take it off. There's only 4 bolts.
A little advice though....get someone to give you a hand unless your arms are abnormally long and you're really, really, really strong.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Thanks very much on this! would you have any pictures to show any dedicated spots of where these 4 bolts would be located? I have the "rs" hatch? i dont have the third tail light on top of my glass hatch; dont know if that makes a difference. (1989 camaro rs i have)
Car: 86 T/A
Engine: 5.0 TPI
It's bolted on at the hinges. Just open it up and look.
If you are planning on installing your existing deck lid onto a new glass you'll have to remove other bolts on the underside of the deck lid under the trim panel and cut the glass loose. With your limited knowledge it's something probably better left to a pro.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
you can do it iv done it more then once... pull the deck lid interior panel off then you'll see the nuts and washers that bolt the deck lid to the glass, there are 2 screws on both the left and right outside that you have to unscrew this is to take off the window trim that wraps around the glass off the lid it will stay with the glass when you unscrew it that then you'll have to use wire to go between the deck lid and glass to remove the window sealnet
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I have a question to add, may help the origonal poster too.
I haven't done this yet, and am sure I will have to pull it eventually.
Well two questions.
1 You adjust the hatch buy the hinge/mounting bolts?
2 Can you over tighten the bolts/nuts and break the glass, or is their a spacer or something to keep the bolts from putting to much pressure on the glass?
Well two questions.
Car: 86 T/A
Engine: 5.0 TPI
Well two questions.
Well two questions.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
good question and thanks for bringing this up
I'm not worried about taking mine off, just haven't done one before, so I don't know what it looks like having not looked and I don't have my car to look at right now.
Just thought that would be good to know, and something you may have wanted to know.
Helps to have imput from several people. That's why I like forums.
Are you sure... I'm pretty sure the hatch just floats there.....
j/k
Here's what the glass looks like without the panel attached, in case it helps anybody. There is some very thick weatherstripping gunk in there that will have to be cut out, I used a piece of thin metal from a sign. Before you put the other deck lid on there you'll need to add more weatherstripping, clear silicone will work as long as you clean everything good first. It's time consuming but it can be done.
Just curious, why are you changing your glass?
