Front nose won't line up with pass. fender, HELP!
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, I'm trying to get everything on my car lined up, and this has me frustrated.. The body lines on this car are giving me migraines.. The drivers fender to the nose is pretty damn close, fairly smooth along the outside, and on the top is good.. The passenger side is alright on the lower parts, but on the top of the fender, on the highest bolt of the nose, it seems to have torn away from the rubberized material.
My question is, how do I fix this? Can I fiberglass it?
900 posts, woohoo!
900 posts, woohoo!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Front nose won't line up with pass. fender, HELP!
glass wont stick to it, you need some kind of epoxy, or i believe there is a "welding" kit for plastics.
Engine: 2004 LQ4
I have some 5 minute epoxy laying around, I'll try that. Thanks, KP.
1 Post
Car: 1987 Trans Am
Engine: 355
Transmission: t56
dont waste your time with plastic welders, the modern 2 part epoxys of today are much stronger then the welders...
Engine: 2004 LQ4
So just epoxy the steel inside the nose to the plastic, then remount on to the fender?
Car: 86 T/A
Engine: 5.0 TPI
I disagree especially when talking about the urethane bumpers on a third gen. Other plastics of today though you're right. Some are damn near unrepairable and 2 part epoxies and urethanes are the only way to go.
Engine: 2004 LQ4
I used a 2 part 1 minute epoxy, and I used my linesman pliers to bend it all back in place. I'll put it back on later and post a pic. Thanks guys, a ton!
